hi all
Ive just recently noticed that in the mornings if i let my car idle for 2-3 mins before i drive it, it performs as it should.
If i drive it straight away or within about 30 secs of starting it...it is quite sluggish...sounds more raspy and really have to plant it to get any sort of boost :(
I was wondering if maybe its not coming out of "cold start" or something to do with the thermostat but i have no idea hence the question
any help would be greatly appreciated as its driving me nuts haha
thanks
  • Replies 59
hi all
thanks
no offence here but why would you be wanting to drive your car hard right from turning the key without warming it up, next is depending on how much work you have done to the car with my experience stock cars generally dont have much of this happen but when you have bigger setups, ie upgraded turbos fuel lines clutches and what not they need to be warm to run smooth, just my two cents worth and prob has something to do with the colder weather coming in
may be wrong here, but a good warmup allows the parts of the car to expand and all fit the running tollerances etc.
along with it allows the oil the get to the top of the engine and all the right places,
starting an engine and hoofing it straight away is just going to do damage to your engine
hey Jeremy and Dave thanks for the reply
i understand about the warming up process, i like to let it idle for a minute or so but sometimes i cant due to time restrictions etc etc
i never boost let alone drive it hard until the oil has reached full operating temp, but even once it does why would the car not react the same depending on the initial idle time?
I wasnt under the impression that the car would react completely differently depending on how long it idles for.
also if this helps, it will only go back to "normal" after it has fully cooled down after sitting for a 4 or 5 hours
i appreciate the help though thanks :(
as i said i didnt want to imply anything but the way you worded it sounded like that lol, i too have been in the same situation where u dont have time to letit warm up, and like you it does run a little slugish, although i have a 300kw setup and a built motor so like dave said the oil needs to be in all the right places for everything to work and when you have a torque turbo like my tdo6 there is very little turbo lag and it is almost like fuel cut and doesnt spool boost over 3000 rpms til warm, so i can sympathise with you and sometimes you think there is something wrong with the car, possible soloution could be to get an engine start remote so you can turn it on from your bed or something lol
fair enough i guess i will just let it sit for a few mins...
however after saying that, in a lot of the threads about "warming up" never seem to indicate any sort of performance difference after letting it idle for a few mins...(i could be wrong in assuming that)
this is something i have always wonderd about. Every car i have ever owned has done this (Mazda 323, 626, Honda Accord, Mitsubishi Cordia, C32 Nissan Laurel) . However when I first buy a car I have noticed its not so bad if not at all. But I have always let my cars warm up from between 3-6 minutes or more depending on the time of year and its seems that the car/engine seems to get used to this condition and routine of warm up.
Can anyone else relate to this?
it can also come down to the tune. because of the cold start function with the coolant temp sensor the car is given more fuel when cold until it warms up basically a choke setup, then it is given the correct amount when warm. also with the idle air bypass valves they get dirty over time and dont idle at the correct speeds etc all just comes down to wear and tear. u dont drive ur car cold for very long neways so harden up wait till its hot and give it hell. my 2 cents
skylinekid you make a good point about the air bypass valve...which makes me wonder whether that might have something to do with it
the idle has been hunting a bit and generally idles smoother/correctly those times when its running "well"
i have a spare aac valve assembly i might swap it over and see if that makes any difference :P
thanks for the idea
This condition is worse for MAP sensored cars. Not that that's much help for OP, but my set-up experiences exactly the same symptoms because its hard to get an accurate vacuum/boost/load signal when things are cold. Don't know why this is, but i imagine Air Flow Meter cars have a similar effect. The condition is definitely more pronounced with the more modifications the engine has i.e. aftermarket ECU, upgraded turbos, Intake manis, cams, injectors etc...
I reckon its a combination of a couple of things:
-Oil is cold and more viscus, thus has more resistance on rotating parts (crank, rods, cams, oil pump etc...)
-Engine is cold and rotating parts are that little bit smaller due to thermal expansion, therefore piston-cylinder wall clearances and thus compression isn't the same. This is even more pronounced for cars with forged pistons or aluminum blocks (ally vs steel pistons, different metals expand at different rates).
-The ECU injects different amounts of fuel on cold start-up, and the AF ratio vs ignition timing (when cold) won't bring about the best, most responsive 'feel'. Also the stock ECU has the perfect tune for cold start-up, to compensate for the above factors, as soon as you start to change things, (as Yts said) this throws that factory tune out a little.
-Extra loads put on the engine (electrical loads (alternator), high steering angles (power steering), air con (A/C compressor).
-Lower intake temps because the intake manifold and head are cold.
In short, it's always good to let your engine warm up to operating temp. before giving it a sting, everyone knows this...
my car has a rebuilt engine, larger turbo, injectors, map based ecu etc. it gets about 15-20 seconds for the oil pressure to come up and then i am off (obviously not thrashing it) and this has only happen when there was a couple of cells out of whack in the tune that meant it ran super lean and lost almost all power as there was next to no fuel going in.
you would be surprised how little time the stock ECUs give the engine before reverting to closed loop cruise and pulling it back to 14.7:1 they cant run it rich for long as it hurts the emissions tests they have to pass and destroys the cat.
hi all
If i drive it straight away or within about 30 secs of starting it...it is quite sluggish...sounds more raspy and really have to plant it to get any sort of boost :P
thanks
What model and what mods? Does your O2 sensor work?
Edited by rob82
For my 2c engines can feel sluggish when stone cold for three reasons .
Firstly the cold gun effect where you're losing a significant amount of combustion heat into cold piston crowns/valves/chambers so less heat to develop cylinder pressure .
Secondly oil shear drag from cold oils esp mineral ones .
Thirdly warm up mapping is different to get heat into the thing quickly because often this is the dirty time for most engines emissions wise . The cat has to be brought up to temp as quickly as possible to be able to work as intended .
I like to give my engines a short idle period to get the fluids circulating internally . One thing you will notice is that a good synthetic oil doesn't have as much drag as mineral ones tend to when cold .
I think what you are feeling is computer mapping that has greater emphasis on warming the engine up rather than giving best performance .
As people have hinted having some mechanical sympathy goes a long way with cold engines , also don't forget the gearbox and diff oils work better with some heat in them and you only get that after driving for a while .
2c spent , A .
he did state hes not planting it, just notices it goes better if he warms it up idling rather than driving easy.
I think this is a common thing, ive experienced it on most all cars ive driven. One of my cars felt lazy if i did the opposite lol, it prefered to be driven within 30 seconds of starting and warmed up with easy driving, then it was alive.
I have a feeling that this is oil related, if ur due for a service soon try run something of higher grade. The best oil I know of is neo gold and you can get it from gccorp.com.au delivered to your door for about $70 for 5L. My motors always ran tops on that stuff, it turned my sludge filled SR to a new looking motor within 1 service (talking about under the rocker). Its also an extended interval oil, i usually keep it in for about 8000.
GL
hi all
If i drive it straight away or within about 30 secs of starting it...it is quite sluggish...sounds more raspy and really have to plant it to get any sort of boost :(I was wondering if maybe its not coming out of "cold start" or something to do with the thermostat but i have no idea hence the question
thanks
Its common knowledge to let any engine get to normal operating temperature before putting any load on it.
Reasons:
- Oil is as thick as honey and can't be pumped or splashed around as easily
- Metal expands and contracts with heat.
- Pistons are smaller so they expand in the block faster in the block making them slightly tighter until warm
- Thick oil pushes out seals
- Engine failure
This should be taught at school. I can't believe some people don't know how obvious this is?
Edited by The Mafia
as the others have said, just drive it normally (dont load it up, dont bring it on boost) until the engine is warm
wamr is considered around 50deg water temp - or when the water temp guage on the dash starts to move
Dont get your nickers in a twist mafia, he did correct himself
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
