Hi Guys,
Does the standard r32 turbo require an oil restrictor in the oil feed?
I have a Turbo diesel patrol that i have been using R32 turbos one, this weekend i blew my seciond 32 turbo so i am just investigating why.
the oil banjo i have for it does have a small oil restrictor and i was just curious if this was stock or not.
oil pressure, what pressure does this turbo need? my patrol pretty much sits at 3 bar oil prssure all the time.
thanks.
christian
https://www.sau.com.au/forums/topic/320578-r32-turbo-oil-restrictor/
    • yeah, there's a country that recently started importing Skylines, I blame them.
