  • Replies 234
Don't laugh, I got sideways into the first exit at the end of the strip in my old '31. And consequently got told not to drift. It wasn't intentional!
But no, I'm not running either car. The Pulsar would break another driveshaft and I can't afford to break the Skyline :(
Two long words...DOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIT
nooooooooooooooooooooooooooooooooooooooooo lol
i will end up frying the stock clutch. not till the buttong clutch goes in will she see the strip :)
Am up for this. Would be good to see what I can do in this. :blink:
**Edit
RE: License - You need one to race far as i understand as it's insurance related (for them), same as Calder which i know you 100% need a valid license to race.
Fairly sure you don't need one mate, can't recall having to in the past, just needed the other stuff, closed shoes, helmet, long sleeves etc.
Here is the Heathcote page with licence heading too:
http://www.heathcoteraceway.com.au/scrutineering.shtml
Delay the court hearing lol, if you get it ajourned to another date you'll be able to continue driving.
soooooo tempting...but i kind of want to get it out of the way...if i do decided to ajourne it what excuse can i use?
That you have a drag day the weekend after which requires a licence? :domokun:
Can someone attend if they (were once a president of the WRX club, and) have been banned from the WRX club for referring the current line of Subaru cars to looking like a rubbish skip full of smashed crabs. Oh and calling the current president a Muppet. :domokun:
Oh and I'll probably be driving a Hiace Diseasel :D
omg ive been wanting to take my car down the quater for shitz n giggles so this is the perfect day.
i must say i wouldn't have noticed it if i wasn't showing my housemate what bonus being a paid member have ! (im positive we will attent the next meeting at bells hotel now)
This day is aimed for street cars isn't it ? i would like to take my silvia, it's not registered because i don't need another rego to pay. won't be a problem will it ?
yay i can test launch, but i think i'm going to need good tyres or even semi's
awesome.
if that person is a VIC SAU member i think the answer is yes.
and i might even get a chance to talk to some wrx members apart from my brother
Quote "No shorts, pants, thongs, open toed shoes in pitlane, only long pants and closed in shoes"
So what is the difference between Pants and Long Pants? lol
Can someone attend if they (were once a president of the WRX club, and) have been banned from the WRX club for referring the current line of Subaru cars to looking like a rubbish skip full of smashed crabs. Oh and calling the current president a Muppet. :thumbsup:
Oh and I'll probably be driving a Hiace Diseasel :thumbsup:
HAHAHAHA I concur with your sentiments about the current line of Subarus and will lend you the keys to my vehicle should you need to take down a WRX or two.
They're longer.
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
