I was at my place of work it is in retail (not a sales man) and was bussy all night. When i finally finished i relised that i had stayed 30 min overtime .. (finished 11:00am)
I was tired and thirsty and i head home post haste salivating the thought of dat der glass of milk / bottle !! When i get home i discover that there is no MILK and the though of no milk for the rest of the night had me in a depressed state.
Then i said fck naw i aint taking this **** i drove to the shops (11:18am) and got me some milk then i though i could by some choclates for my mothers day is tomorrow then. I rembers i forgot my wallet so i could not debit but $5 for the milk so the chocolates went back and i c this chick that goes to my tafe she is the check out chick, only one register open hers i seen her b4 never said hi .. i said ill say hi so i
i said "hi i seen you around tafe"
she"oh yeah said some other bull ****"
i said "i always c u around what course u doing"
she " im doing some management course wut course are u doing"
i said " i told her asked when is she finishing it she said soon and she wants to do nursing"
by this time she had scanned my bottle of milk and i had given her the money she so i say
i said " good luck and left"
she "pardon"
i said " good luck"
she " thanks"
i said "cya"
she "bye"
on the way out the security guard said cya
i said "cya"
I proceeded to walk switfly to my car when i got in my car i opened dat der bottle of milk and proceeded to drink it in the parking lot with milk running down my chin and the smile of satisfaction and the feeling of euphoria in me.
https://www.sau.com.au/forums/topic/320626-milk-after-work-must-read/
Guest
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
