nah I always leave it till the pump is primed. I hear it Click off in the boot (noise courtesy of the big bosch pump :)) but it still is hard to start. most times have to touch the pedal. esepecially when its cold.
also clutch is really loud till you hold your foot in on the pedal.
When is the last time you got your injectors cleaned and flow testered?
  • Replies 121
i have a relay in the boot that keeps clicking. i think its for the hicas pump. ive been told its a bad earth or something. any ideas anyone? does anyone know where the major earth points are for the wiring system?
4. still cant get to blow air up on the front windscreen with the AC off.
I think this is normal? Mine does it too? Its annoying when its cold and you have to have cold air blowing in to demist the screen
  • 2 months later...
I think the wiring in my car is loopy, i believe it thinks the boot is always open (int light on and boot light on, i had to remove), and the alarm believes this too. normallly that is ok, alarm ignores that one trigger point, but yesterday alarm started going off for no reason, and keeps doing it. had to turn stupdi siren off...
Anyone have ideas about wiring & how to fix? This is actually REALLY annoying me....
i've got a whining noise coming from my steering column... but the dirty sanchez dosen't make the noise when i take it to the mechanic, but it starts up again the moment I get home. I've made around 10 trips to mechainics, only to have em look at me n go "what noise?".
My car is a dubious manipulator. The voices in my head agree with this too.
No really I have a whining noise which comes on and off. it increases in pitch when the car is moving faster. The faster my wheels are turning the higher the pitch. Its inaudible from the outside and while inside it seems like its coming from the steering wheel.
One of these days I'll gut the car to find a worn out bearing causing it and I will rage out on that bearing making the rest of its life a living hell.
this makes me feel good about my car, nothings really wrong with it like this, 1 or 2 rattles i've still gotta find , got rid of about 3 already...
sometimes i have to look out the left hand window to see where i'm going when i go around a corner on boost.... i think thats my tyres tho :D
i have to have the air con on to get the air on the windscreen too.
Yup... my aircon automatically switches on if I just press the demister front or rear.
The freaky stuff my car does atm is below:
-> when cold the break pads sqeeak... very bad.. ok after I drive the car and use the breaks a lil.
-> RATTLING! dammit I had rattling and I still havent even put in my sub yet. :D Thinking of taking out the trims and re-sit them backin and see if it will solve me rattling problem.
-> A flat spot? at ~2 or 3000rpm, tho I think it might be due to the triptronic gearbox or something.. not sure yet...
-> After the car warms up the idle is not constant.. (some misses) or when I park my car on an angle with the front higher than the rear.. Taking this back to the mechanic workshop soon to work out why..
-> Tendency to attract lots of people around it.. ;)
Other than these. I am prefectly happy with my car. :D
HA its a japanese Tuner and tape player.. dont have any tapes and cant get Aust stations... Fcuking thing!
There is an easy (and cheap) solution.
You can get a handy little frequency converter that plugs in between the antenna and the radio.
It converts all the frequencies (shifts them up or done) so they match the Japanese range the radio recieves.
I have it in mine and it works quite well, the only flaw is that the radio still displays the jap frequency so for example 105 may display as 97 :)
well.. mine seems to over heat every so often.. it'll be fine for a while.. then boom.. it will sky rocket to the H mark and steam will piss out every where. I just had the system checked etc because it shat itself a while ago... damn thing.. just did it again tonight..
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
