R33 Few Parts + Turbo Upgrade.
Hey guys i have a few things sitting around,
2x r33 gtst ecu's (i have 1x a non turbo aswell i dont need)... $50 each or both for $80
1x standard grill "black"
1x trust spoiler "black"
1x standard low standard spoiler "black"
High flow turbo specs are.
Hiflowed turbo with standard front with Garret gt30 wheel, ar63 rear. car had 270rwkw with it on. $400 (offers are accepted)
Located in Sydney.. buyer can orginise shipment if wanted!
call me on 0432546726
Edited by Stealthynsa
what condition is the turbo in does it have any shaft play?and will it fit a standard manifold?
yes straight fit onto a standard manifold... im giving a 3" dump pipe back to cat for the turbo so it can fit straight upto your standard setup.
minimal shaft play not much at all. turbo was in perfect condition when last used
dyno sheets??
when did the turbo make full boost? how much boost running to make the 270kw?
who did teh highflow?
sorry its been a while since ive used the turbo dont have the dyno sheet for it.
i ran the turbo on 14psi never got a dyno sheet since i was in the process of adding other mods but
my mate offered me a bigger turbo so i didnt bother upgrading parts and tuning to this turbo..
my friend that owned it if i can recall said he had is on about 19psi for 270kw with supporting mods ofcourse.
 Share
    • It depends on what the guy who bought its Ratio is. Mine is a 4.36 Jus Jap told me anything above a 3:9 has equal length shafts which the Nismo center's shafts were not.
    • If those shafts in the last 2 photos are the ones that came with the diff, you have no hope of fitting the other ones because they are completely different
    • I have recently fitted a Nismo GT Pro Center second Hand buy still in the box i got stubs with it but they are 5 bolt and I need 6 (3x2) I was told by Just Jap that for a 4:36 ratio the stub axles are equal length sku 38220-0V161. They didn't have any in stock but I picked up the ones pictured. The one with 5 bolt are the ones that came with the LSD. The right side went in no issues but the right....I have happened the fk out of it put it in a press and it still sticks out about 5mm too far. It was sticking out about 25mm but after bashing it like Chris Brown did to Rhianna I managed to get it a bit further in but seems stuck again now. Any ideas? Should I just leave it 5mm out and send it?
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
