i had a spare and need it gone
its had a rebuild kit put through it for 1000(replaces everything except for the flywheel)
so its basically new
all part re-machined
comes with new throw out bearing ect
this is bolt in and basically brand new for half the price of a new one
located in NSW ( lower blue mountains)
1200 bux
30 bux delivery anywhere in aus... but i would prefer pickup
pete
0448468884
https://www.sau.com.au/forums/topic/320659-os-twin-plate-sydney/
