Hey every just finished my conversion yesterday and finally got it runnig. The story is the motor came out of a s13 so it was ready to go back in well it was just the mounts none of the wiring was done. I did the wiring which was fairly easy 2 wires ign one ecu memory and other is fuel pump everything else works fine. Now when i start it idles perfect can give it a few good revs for about 1-2mins and then it starts missing and wont go away. Ive changed eng loom tried 2 ignition modules 2 afms replaced coilpacks new spark plugs and changed o2 sensor. The only thing that i can think of is that i opend the ecu and found a burnt track, repaird that by soldering a wire and tested the track working perfectly could something else in the ecu be faulty? it also doesnt have the cold start valve so the hoses are just blocked for now. its really doing my head in and if anyone has an ideas would be a great help
Edited by gelousi
https://www.sau.com.au/forums/topic/320675-rb20-wierd-missfire/
ecu is telling you there is a problem run a ecu diagnostic witch makes the ecu flash so many times eg 5 and number 5 is your problem. if that makes sense search on google for it.
try resetting your ecu first.
anyone else experience this?, i spoke to a mate he rekons i need to run a ign wire to power the coilpacks as they might not be getting full power which is strange because ive gone off the factory wires on the loom which are, black/red and white both joind to the black/red on the s13 loom which is factory ign, then ive got my white/black going to the factory red which is ecu backup i have read nothing at all about adding another ign wire to coilpacks if i was to give it a shot where to the coilpacks get power from is it the 3 pin plug near the ign module? thx
Could be many things when it comes to miss firing, you can try clean your AFM with CRC contact cleaner.
Also check the injectors and wires that gose into each injectors, or take to the mechanics and do some
fuel pressure test ! There are many variable for the miss firing problem. Best way is to start from something
easy and work you way up... or try
check earths. main one from engine.a mates did the same idled fine but as soon as you reved it up missed like a bitch. we found the earth lead from block to chassis rail corroded and fricked. changed it and after it was sweet. run a jump lead or thick wire from engine to good earth point on chassis or even better still battery to check.
Hope this helps good luck!
FIXED! was getting 15v from the alternator :S nowere in the conversion guide does it tell you to use the origional ca18 alternator loom there is one plug that is wrong. Ahhh the beuatifull power of a rb20 in a s13 its amazing!!!!!
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
