check here http://www.skylinesaustralia.com/forums/St...kes-t82083.html, it answered all my questions, i've got r33 gtst (sumitomos) 4 pots and gtr discs on the front of mine but as they were on it when i got it i couldn't say if they were a straight swap.
https://www.sau.com.au/forums/topic/320696-m35-brakes/#findComment-5234528
Not a straight swap but close enough. R33 gtr have the same bolt pattern but require a small spacer and a sleeve. R32 gtr just require a sleeve.
The M35 uses 14mm bolts and the Sumitomo's run 12mm bolts.
The braking doesn't feel much stronger, just more consistent and they don't fade like the stockers. Also performance pads are easy to find.
https://www.sau.com.au/forums/topic/320696-m35-brakes/#findComment-5234551
Or get some 350Z brembos. See Danny's tutorial here: http://www.skylinesaustralia.com/forums/M3...p;hl=m35+brembo
Pretty simple upgrade as long as you have wheels big enough to fit them.
I Just picked up a set off ebay and will be doing the same conversion next week when they arrive.
Cheers,
Ben.
https://www.sau.com.au/forums/topic/320696-m35-brakes/#findComment-5234617
http://www.skylinesaustralia.com/forums/M3...p;hl=m35+brakes
This threads a bit old.....if you want to go bigger R33 GTR rotors and callipers should bolt straight up as well
Edited by Jetwreck
https://www.sau.com.au/forums/topic/320696-m35-brakes/#findComment-5234638
looking at getting D2'S 356 but they dont list them for the stagea so will it be the 350 z or the skyline gts or gtr or the v35 dont know which , think they will be more like the 350 z ?
350z or v35
Edited by iamhe77
https://www.sau.com.au/forums/topic/320696-m35-brakes/#findComment-5235703
Hi Scotty ,where do the spacer & sleeve go & how do you overcome the bolt size problem?Wish to try this upgrade so I need all the wisdom I can Get
Thanks Cad
https://www.sau.com.au/forums/topic/320696-m35-brakes/#findComment-5235842
I used my lathe to spin up the spacer tube so it fits over the 12mm thread. It has to be 1mm thick, 12mm internal and 14 mm external. 12mm long I think. From what I have seen the r33/r34 gtr will also require a small spacer between the calliper and mount also, the r32 gtr callipers I used didn't, the disk was perfectly centered in them.
https://www.sau.com.au/forums/topic/320696-m35-brakes/#findComment-5235961
Scotty are the 33 & M35 disc's the same thickness? Thanks Cad
https://www.sau.com.au/forums/topic/320696-m35-brakes/#findComment-5236243
Put your tool away, no need to show off :thumbsup:
Im not sure what the r33 disks are but the r32 gtr disks are 32mm. The M35 disks are about 20mm thick.
M35 fronts are 24-25mm thick, R33 are larger than R32, so will be much thicker than the standard M35 discs.
https://www.sau.com.au/forums/topic/320696-m35-brakes/#findComment-5237286
is there a kit out there to fit the mn35 , or does it share the same brake kit as a difrenet car like the v35 ?
K Sport do a 6 & 8 Pot kit for them. . pretty straight forward. . .but cost is around $2400 a pair. . use Brembo rotors for replacement and various pads like hawk and ferodo . .
A & B motor sports and others do them. . here in Sydney. . just google k sport and you will see options. . they are the V35 skyline ones.
https://www.sau.com.au/forums/topic/320696-m35-brakes/#findComment-5237902
Well I have my 33 twin pot front callipers and crossed drilled slotted 32gtr disc.Wish me luck cause I will probably need it. Appreciate your help. Cad
https://www.sau.com.au/forums/topic/320696-m35-brakes/#findComment-5238181
What wheels do you have Scotty as the 33 callipers hit my standard wheels
https://www.sau.com.au/forums/topic/320696-m35-brakes/#findComment-5248087
17 x 9 inch Driftek's, (+30 I think) they fit like a glove other than the fronts hang out half an inch.
The rim clears the curved brace under the coilover by 3mm and I have 235 45 17 Kumho KU36 tyres. (speedo is out by 11 ks at 100.) Highly recommended.
https://www.sau.com.au/forums/topic/320696-m35-brakes/#findComment-5248434
Hey scotty dont want to appear stupid but will the offset stop the rim from hitting the R33 upgrade callippers or is it the shape of th basket on the rim.
https://www.sau.com.au/forums/topic/320696-m35-brakes/#findComment-5249391
  • 3 months later...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
