Item: 1987 Nissan Z31 200zr
Item Condition: Good
Reason for selling: Need a more practical car, unfortunately time to move on see below
Price: $10,000 - No Swaps
Contact: Mob: 0401 840 770, Email:[email protected], PM or msg here
2 door Targa Top coupe, 2+2
Factory RB20DET
5 speed Manual
Factory LSD
Last straight 6 Zed car built by Nissan
Rare Nissan import
- Imported in 2003 by an import car yard, have importation documents
- First owner bought it from the importer in 2004
- I'm the second owner in Australia. Purchased it off the first owner end of 2006
- Mod plated as a grey import 15 years and older
- True KM unknown due to odometer stopping approximately 3 months after I bought it. Odometer stopped at 123,770KM. A conservative estimate would be about 160,000KM (I would have been lucky to do about 10,000 KM a year)
- Rego until October 2010
- Not selling with RWC but an arrangement could be negotiated if you wanted to keep it registered
Modifications
16" American racing 2 piece rims
KKR 430 turbo & dump pipe
Suspension fully redone
Cusco Strut braces imported from Japan
3" Straight through exhaust
HKS BOV
R31 5 speed manual (converted in Japan)
Aftermarket fuel pressure regulator
Front lip
Bomex side mirrors
Side windows tinted
Aftermarket boost gauge
Sony MP3 head unit
R32 drivers seat
Greddy turbo timer
Remote central locking
Hornet alarm/ immobliser
K&N air filter
Probably heaps more that I have forgotten about!!!!
Issues
Aircon needs re-gassing
Drivers side power window needs help getting up and down
Speedo, odometer or trip meters don't work (cluster related problem)
Original paint showing its age
Some panel rust
Factory boost and oil pressure gauge not hooked up
Some gutter rash on all rims
Fog lights don't work. Replaced with strobe lights.
Mechanical History
- All major work undertaken by myself or done at either Advance Performance Center, AMEC (unfortunately closed due to GFC best workshop I have ever been a customer of), 101 Motorsports
Receipts for ALL work done on the car:
- Heavy duty clutch fitted 2006 (by previous owner, unsure of brand possible Exedy)
- O2 sensor replaced 2006
- Rear Passenger side wheel hub repaired. Stub axel re-machined and bearings replace 2006
- Greddy turbo timer, Hornet alarm and remote central locking fitted (Autobarn) 2007
- Side windows tinted (Solace Tinting) 2007
- Full 3" exhaust mild steel Dump-pipe back with new Magna-flow cat (Right Price Exhaust) 2007
- Rocker cover gaskets replaced 2007
- Power steering rack rebuilt (All About Steering and Suspension) End of 2007
- Suspension completely redone. All bushes replace ect. King springs in the front with good KYB shockies. CUSTOM King Springs in the rear with adjustable Koni shockies (All About Steering and Suspension) End of 2007
- Radiator flushed x2, gearbox oil changed x2, diff oil changed
- KKR 430 turbo and KKR dump pipe with Vee-band clamp fitted. Exhaust manifold was removed and broken studs replaced and manifold was heat wrapped end of 2007
- Crank angle sensor replaced start 2008
- Injectors removed and fully serviced, Coolant temp sensor replaced April 2008
- New Champion battery May 2008
- Cusco strut braces imported from Japan fitted June 2008
- MAJOR SERVICE DONE. All belts replaced including timing belt. Water pump replaced, cam seals replaced. June 2008
- All radiator and cooling system hoses replaced during 2009
- Air Flow meter replaced with recoed one start 2009
- Dump pipe Vee-band clamp removed and properly cast welded June 2009
- GEAR BOX REBUILT. Fully striped with all bearings and 1st/2nd syncros replaced July 2009
- Power Steering rack mounts replaced (All About Steering and Suspension) Jan 2010
- Currently has Maxxis tires on the front 80%, Kuhmos on the rear 100%
Well the time has finally come and I must now sell my pride and joy due to a combination of reasons. I need a more practical car for work as I will be heading up north and possibly going remote. Also looking to get a slower car to save my license due to getting a number of speeding tickets last year! And ultimately the time has come to concentrate on my career so cars and drifting have taken a massive backseat, especially in the last year.
I have spent thousands of dollars on this car both modify and restoring it. My main focus was to improve it mechanically to enjoy as a daily cruisers with some light track work. Yes this car has been tracked at Archerfield but only a few times. As it was my daily I was very cautious as it had to get me to work the next day, so no limiter bouncing or aggressive driving. It has served me well both driving to work every day for the last few years, and out to Gatton every couple of weekends for the last year. The car has always been religiously serviced every 6 months using only premium oils (either Castrol, Valvoline or Motul). It has been tuned for and only every run on BP Ultimate fuel (98 ron). Sticker on the timing belt cover said in Japanese that the belt had been replaced at 87,XXXKM but I did a major service just to be on the safe side at approx 145,000KM.
As this car is quite unique I would love to see it go to a good home. If you consider yourself a Zed car, classic Japanese or import car enthusiast I would consider a significant price reduction. This vehicle is a real head tuner and I have had many conversations in car parks/car shows ect with complete strangers wanting to know more about it!!!! I really dont want to sell it as with all project cars they are never complete but unfortunately the time has come. It is great to drive and with some new paint and body work would look fantastic. It could also be easily converted with any RB engine of your choice to become a real weapon!!!! Please feel free to call me with any questions or for any more info.
https://www.sau.com.au/forums/topic/320701-1987-nissan-z31-200zr/
  • 3 weeks later...
  • 3 weeks later...
Now down to $6,000. Also have a brand new FMIC to suit never fitted, manual boost controller never fitted, pair of Z32 alloys and heaps of other spares that can be included in the sale if wanted.
  • 4 weeks later...
  • 3 weeks later...
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
