Hey,
I recently bought an s13 which had a rb25 in it, I was going to put an SR back in it so no longer need this, it was taken out of a low km halfcut, I want to sell it complete or will part it out, also clearing out other stuff I dont need, all parts are R33 RB25DET uness otherwise stated:
Prices negotiable but NO LOWBALL OFFERS
R33 RB25DET complete motor with accessories $1700
R33 RB25DET long motor (block and head) $1000
ps pump $80
alternator $80
starter motor $80
a/c compressor $60
CAS $100
stock turbo $250
stock exhaust manifold $50
stock turbo lines $45
stock dump pipe $40
stock front pipe $60
coilpacks $40 each or $200 for 6
injectors $20 each or $100 for 6
afm $60
inlet manifold/plenum modified to be forward facing, about 90% complete still needs a little work to finish it $120
ecu $100
flywheel $60
new exedy button clutch $490
engine mounts $40
RB20DET gearbox $400
R32 GTR brakes, front and rear rotors, calipers and pads $790
R32 GTR NISMO Cat back exhaust $320
R32 GTS-T HKS cat back exhaust $320
Im located in Randwick (Sydney)
Reply here, PM, or call/msg <removed>
  • 3 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
