My port looks like that, but I don't have the cable. Nor the 'BOSE for Skyline' badge, even thought I have the BOSE stereo (SP model).
Mines all Infiniti badging anyway.
BTW am in touch with a company in NZ that makes the band expanders - only $30 NZ delivered for very high quality ones.
Still need to work this out: 'Also I would need to know what type of antenna plug is in the back of the radio unit eg. A single plug or a twin pin plug as these model vehicles varied."
Anyone know?
There are quite a few band expanders available here in NZ, quite a few advertised on TradeMe also
Before you order one check what Mhz you require, they generally come in two different Mhz ranges and you will need to decide which is appropriate for the FM signal range that you use
Very easy to install for most cars, except for Nissan and those damn aerial plugs they have. TradeMe also usually has adaptors for the Nissan aerials listed
Hi David,
Thank you for your enquiry. What area are you in Australia so I can
work out the frequency range you would need and also are the main stations
you listen to in the higher band range eg.over 100MHz? Also I would need to
Regards,
Peter
Hi Peter,
I'm in Melbourne. I like to listen to as high as 107.5Mhz and as low
as 89.9Mhz (or perhaps a little lower).
Is there an easy way for me to determine the antenna plug?
How much are the units + shipping?
Regards,
David.
Hi David,
The unit you need is a 10MHz which will allow reception below 100MHz
by deducted 10MHz from the station you want and 20MHz deduction for stations
above 100MHz. The cost is NZ$30.00 including airpostage.
There is no easy way. If the radio is a factory unit then it will probably
have a twin plug as they have a diverse antenna. If it has had the Bose
system installed instead of the factory unit then it will more than likely
have a single plug.That's as close as I can tell you.
Payment per Visa/Mastercard or PayPal or Bank Direct credit if you can do
that from Australia.
Regards,
Peter
Peter Brixton
fmBand Expanders
PO.Box 981
Christchurch 8011
New Zealand
Ph.+64 3 3666379
Fax.+64 3 3656197
Mobile.+6421356219
E Mail: [email protected]
Web.www.fmband-expanders.co.nz
  • 3 weeks later...
Hmmm... don't suppose you took a photo? Did you order one from fmBand Expanders in NZ?
I'm going to have a Tom Tom (Mini USB) plug wired in too while I'm at it.
If I CBF'd I was going to investigate having a mini SD set top box powered and connected up to the AUX. Unsure how the reception would be though with little/no aerial.
Hey - is your V36 manual? If so Geoff told me about yours.
I'm in Hobart regularly on business. If you ever come down this way let me know. Would love to bring my one over on the ferry but don't know if I could be bothered with the 10+ hour trip.
Edited by Haxorz
Hey, yeah it's a six sp. Didn't take a pic, spat it when it didn't fit and just left it. Got it from Leading Edge.
What do you do for a crust that brings you to Hobart?
Boat trip isn't that bad, I've done over half a dozen times (not much on flying).
  • 11 months later...
It's comforting to know the AFS OFF flashing indicator was because of the HID's being removed. That was my theory but considering I saw a little movement from my headlights before it would start flashing, I wasn't too sure what to think. I'm guessing the motorised assembly is getting jammed on something so to avoid burning anything out, it then switches it off.
I've left my AFS switch in the off position until I refit my HIDs on my next day off (and hopefully dry weather).
  • 1 year later...
Hey guys, ipod connector, from japan so this should work on our cars
Found the part looking through Electronic Parts Catalog for CKV36
http://nissan.epc-data.com/skyline_coupe/ckv36/7299-vq37vhr/misc/
83208-9925 ->
Edited by Mclarenmercman
How can you say its an ipod cable? there are no pic ref for that part number, i reckon they are for the different phones they have in japan, none compatible in Aus probably...
83208-9925 ->
  • 1 year later...
I would like to write a conclusion for this thread.
1. Both headlights move with steering
2. AFS function is fully restored when you revert back to D2S hid
3. Light emission 'pattern' is back when you revert back to D2S hid.
Adr compliance is stupid. Nissan design its headlight to run oem hid. People here switch it out to standard halogen globe, predominantly H1 size in which has different focal length. Then what you get is NO LIGHT THROUGH THE CENTRE OF YOUR VISION, short visible distance and your AFS malfunctions. Dangerous?? But the adr wants it that way...go figure!
Fortunately if the workshop who did the compliance are smart and proper, buy the D2S hid globe and it only takes 30mins to revert back to hid. At least it was on my 08 V36
Of course. They're trying to follow the UK one I think, with the washers etc. That's great for apline regions, don't need it in Aus. Either way, if it works for the Japanese, why can't it work for us?
Oh that's right, 50% of the cars on the road have the headlights pointed too high. Literally nothing can be done about that, even if you put adjusters in as standard (which is the case in Europe).
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
