Hi all.I just put a AX53b70-25 turbo on my car and had it tuned.Made 299.2 rwhp on 16psi but i reckon boost comes on later than it should.I have attached a photo of the dyno sheet.Im thinking it may be an actuator problem as it doesnt seem to hold boost very well up top as seen in the dyno sheet. post-52441-1273888340_thumb.jpg
https://www.sau.com.au/forums/topic/320720-is-this-too-much-lag/
  • Replies 53
yeah i would expect it to come on a bit earlier
what car? manual? auto
how is it tuned?
how do the AFRs look ?
8psi by 3300rpm hmmmm
it just looks sluggish - theres no real whack
how is your boost control?
try it on the dyno on unlimited boost mode
what did the tuner say
does it knock
Boost control is poor - Fix that and you'll improve the setup.
it takes 1000rpm to go from 14-17psi or there abouts.
You can see it climbing perfectly then slows up, and then noses over... issues there for sure.
Would the boost tee be responsible for it being laggy or more likely the wastegate actuator? I noticed that the mechanic hooked up the boost tee to a nipple on the elbow of the turbo where as before it used to go to the intake manifold.Would that make any difference?
I think you need a bit more pre tension on the wastegate actuator, the boost is too soft and fluffy, needs some more aggressiveness, a few winds of the wastegate arm should change some things, take it for a spin and experiment with different tensions, then once your happy with the boost, take it back and get a final tune/run I reckon.
yeah there isnt enough pretension on the actuator
ie its either loose or just on the edge
so when its ramping on boost , its probably part leaking / part open
which means you are loosing out on the backpressure in the housing
bassjunky had this on his GCG hiflow with a new actuator (from memory)
end result was it was sluggish and took ages (like yours) to get on boost and full song
he bent the actuator rod (temp fix) and instantly it would ramp to full boost around 3000rpm
i forget how he fixed it in the end, but a quick bend of the actuator rod was enough to give it some tension so it wouldnt leak/bleed off
for those who are reading a general tip
if you are trying to debug boost build / wastegate / boost controller issues
the quickest way to find out if its leaking / stupid controller / wrong settings / wrong control etc
find the VAC line or signal line to the boost controller (or actuator) or gate and unplug it
tape up the VAC line so you aren't leaking to atmo from the manifold and then drive
ramp the engine on full load in say 3rd gear but be prepared to back off as its running unlimited boost
you should be able ramp past 1 bar pretty quickly (be careful and dont run much past this)
ie back off when you go near 3000rpm. if you are able to build your ideal boost early, this is your "quickest possible boost build map"
ie the quickest possible time your engine can load up the required pressure
the next step is to setup your controller / gate / boost controller / etc to run with that desired ramp rate (ie work correctly) and control when target boost is met
Thanks for that mate.I just had a crack at it and all the sudden when it came on boost i heard a loud pop and the car died on me.Started it back up but wouldnt idle.I thought-oh no ive blown something.Got out and looked around the engine bay and found an intercooler pipe joiner had popped off! I think i have just found my culprit with the boost problem.I believe its been leaking at high pressure for quite some time.Haven't taken it for a test drive to test the actuator again yet,i'm changing my undies from when i shit myself when i thought i had blown the turbo or something :)
I use to run the same turbo on a Neo rb25, poncams and power FC etc.
15psi only netted 250rwhp
The tuner (godzilla motorsport) had problems with boost control. We concluded the actuator was not much good.
I never solved the problem and have since removed the turbo and put a bigger one on
I have heard of the same apexi turbo's having similar problems when you try and run 15++psi
This turbo should be no laggier than the stock. They are only rated at 380ps and still run a ceremic exh wheel for faster spool.
They can handle more boost than the stock turbo. The only one I have heard of spitting the exhaust wheel hit 25psi.
Thank you Paul
yep mine was seeing 14psi at like 3000rpm.. and wouldnt boost more than 15psi due to the actuatuor being blah..
so we fitted a big can one and fixed it!
great turbo.. made a very responsive 250rwkw!
Thanks for that mate.I just had a crack at it and all the sudden when it came on boost i heard a loud pop and the car died on me.Started it back up but wouldnt idle.I thought-oh no ive blown something.Got out and looked around the engine bay and found an intercooler pipe joiner had popped off! I think i have just found my culprit with the boost problem.I believe its been leaking at high pressure for quite some time.Haven't taken it for a test drive to test the actuator again yet,i'm changing my undies from when i shit myself when i thought i had blown the turbo or something blush.gif
bahahah yeah I've done that soo many times! and every time I shit myself just as hard lol Good luck man.
So what was the new actuator you put on and where can i get one,if you don't mind me asking?
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
