buckets Posted May 15, 2010 Share Posted May 15, 2010 hey guys for the past couple of months my car has been making an immensly loud squeel on start up, only when cold and i wasnt too worried about it at the start but on a drive home last night it happened while i was driving so im concrned now. i managed to get the bonnet up and someone else to start the car and from the looks of it none of the two belts are slipping, and the screeching noise sounds like its comming from the opposite end to those belts. a bearing maybe? any ideas on how to fix this would be beautiful! Callum Link to comment https://www.sau.com.au/forums/topic/320725-squirl-mincer/ Share on other sites More sharing options...
R34 -_- Posted May 15, 2010 Share Posted May 15, 2010 CRC or silicon spray all the bearings etc that the belts run on. I usually do it every now and again even tho its never happened to me Link to comment https://www.sau.com.au/forums/topic/320725-squirl-mincer/#findComment-5234889 Share on other sites More sharing options...
buckets Posted May 15, 2010 Author Share Posted May 15, 2010 CRC or silicon spray all the bearings etc that the belts run on. I usually do it every now and again even tho its never happened to me ive siliconned sprayed all the bearings i could get to, so ill post back if it did anything or not. it just doesnt seem though like its comming from the front of the engine, it sounds like sh*t i hope this isnt serious Link to comment https://www.sau.com.au/forums/topic/320725-squirl-mincer/#findComment-5234916 Share on other sites More sharing options...
MrStabby Posted May 15, 2010 Share Posted May 15, 2010 Bearings will make noise all the time if they're stuffed. More likely to be belts - have you checked the tension? You can probably tighten them up again if they're loose, but if it were me i'd just replace them if they dont look perfect. Link to comment https://www.sau.com.au/forums/topic/320725-squirl-mincer/#findComment-5234995 Share on other sites More sharing options...
tiberis Posted May 15, 2010 Share Posted May 15, 2010 From personal experience, i would be looking at the alternator belt in particular. the screech on start would be the alternator kicking in and trying to charge the battery as quick as it can due to the charge lost when cranking. then usually the alternator starts spinning/ the regulator tames it down and the screech stops. there should be the correct tensions and where to check deflection in the engine manual that's floating around. oddly enough though, i currently have the opposite problem. at high rpm (4500+) i get a screeching and i have no idea what it is. Link to comment https://www.sau.com.au/forums/topic/320725-squirl-mincer/#findComment-5235292 Share on other sites More sharing options...
R34 -_- Posted May 15, 2010 Share Posted May 15, 2010 (edited) Just for the record, a lot of of old jap cars/vans like the nissan vanette etc squeal on start up and idle so it cant be too serious, just something small that bosses cant be f**ked paying for to be replaced lol. I only mentioned lubing the bearings as iv heard mine starting to squeal while idling, probably got dust etc in them and the lube they would have had (if serviced properly) has dried up which would cause a squeal until they start moving. Try all the small things first so you can eliminate the problem before spending money on unneeded repairs/parts, ring a local mechanic and ask him what the common causes are of squealing and you should get a few answers pretty quickly Edited May 15, 2010 by R34 -_- Link to comment https://www.sau.com.au/forums/topic/320725-squirl-mincer/#findComment-5235689 Share on other sites More sharing options...
ARTZ Posted May 16, 2010 Share Posted May 16, 2010 (edited) From personal experience, i would be looking at the alternator belt in particular.the screech on start would be the alternator kicking in and trying to charge the battery as quick as it can due to the charge lost when cranking. then usually the alternator starts spinning/ the regulator tames it down and the screech stops. there should be the correct tensions and where to check deflection in the engine manual that's floating around. oddly enough though, i currently have the opposite problem. at high rpm (4500+) i get a screeching and i have no idea what it is. Haha.....I got both problems...fixed the second one, wasnt to worried about the first, though it is annoying when everybody keeps telling me to tighten my fanbelt... Edited May 16, 2010 by Arthur T3 Link to comment https://www.sau.com.au/forums/topic/320725-squirl-mincer/#findComment-5235884 Share on other sites More sharing options...
buckets Posted May 16, 2010 Author Share Posted May 16, 2010 alright cheers my belts all seem to be fine and intact, no wear on them, i also got a rag and wiped them down to eliminate any possible fluids on them the only thing is it squiels while its cold, once the engine is at opetating temperature, if i turn the car off and on again no squeal occurs i thought it may be a possible belt thats too tight? considering its happening when its cold and not when it hots, the old saying heat = expansion? could this be possible also? Link to comment https://www.sau.com.au/forums/topic/320725-squirl-mincer/#findComment-5235887 Share on other sites More sharing options...
ARTZ Posted May 16, 2010 Share Posted May 16, 2010 Mines being doin it for ages mate so Whatever it is ,i wouldnt stress about it to much you'll find the answer soon enough.. And when you do please tell me... Link to comment https://www.sau.com.au/forums/topic/320725-squirl-mincer/#findComment-5235893 Share on other sites More sharing options...
buckets Posted June 6, 2010 Author Share Posted June 6, 2010 had a look at the engine yesterday, noticed some major slackage on the alternator belt, so tighten that up and bam. no squeel! my only question is, how do i stop it from becoming loose again? Link to comment https://www.sau.com.au/forums/topic/320725-squirl-mincer/#findComment-5278253 Share on other sites More sharing options...
Nigel Nichols Posted June 7, 2010 Share Posted June 7, 2010 had a look at the engine yesterday, noticed some major slackage on the alternator belt, so tighten that up and bam. no squeel!my only question is, how do i stop it from becoming loose again? Once you have tightened the tensioner bolt just tighten the lock block bolt. Just make it hand tight. No need to over do it with a 25 foot torsion bar. The bottom main pivot bolt only needs to be reasonably tight. The belt squealed when the engine was cold until the belt warmed a bit and gripped better. Nigel Link to comment https://www.sau.com.au/forums/topic/320725-squirl-mincer/#findComment-5278957 Share on other sites More sharing options...
