Hey, this got me wondering the other day. Called up the tyre shop (Tyre Barn specifically) and asked about the choices on 225/40/18s for my Impreza. They replied with 2 choices: Silverstone Evol8s ($185 each) and Hero Milanza HZ1s ($150 each). I decided to go for the more expensive one as it sounded more legit (probably named after the racing track Silverstone too :)) and i've never heard of Hero at that time. Was getting tyres fitted and couldn't help but to go check out the Heros while waiting. These are the stats i got (forgot the treadwear but they were in the 400 mark):
Silverstone Evol8 (made in Malaysia) $185ea
225/40/R18 92W
Traction A Temperature A
Hero Milanza HZ1 (made in Taiwan) $150ea
225/40/R18 95W
Traction AA Temperature A
So are these tyre readings rated by the manufacturer or as some Australian standard thing? Would i have been better off choosing Heros next time because of the ratings? Anybody with experience?
Hey, this got me wondering the other day. Called up the tyre shop (Tyre Barn specifically) and asked about the choices on 225/40/18s for my Impreza. They replied with 2 choices: Silverstone Evol8s ($185 each) and Hero Milanza HZ1s ($150 each). I decided to go for the more expensive one as it sounded more legit (probably named after the racing track Silverstone too :() and i've never heard of Hero at that time. Was getting tyres fitted and couldn't help but to go check out the Heros while waiting. These are the stats i got (forgot the treadwear but they were in the 400 mark):
225/40/R18 92W
225/40/R18 95W
They are probably named because you need to be a hero to use them, or have huge kahooners :)
I'd say they probably belong on a taxi :P
If they have a treadwear rating of 400+ it's unlikely you'd ever need to replace the tyres....... you'll wrap your car round a tree long before you wear the tyres out :ermm:
Most tyres I use have treadwear ratings around 200 .... you don't get a million miles out of them BUT they keep me on the bitumen :banana:
They are probably named because you need to be a hero to use them, or have huge kahooners :D
I'd say they probably belong on a taxi :)
If they have a treadwear rating of 400+ it's unlikely you'd ever need to replace the tyres....... you'll wrap your car round a tree long before you wear the tyres out :(
Most tyres I use have treadwear ratings around 200 .... you don't get a million miles out of them BUT they keep me on the bitumen :ninja:
Lol trust me it's 400 or 420 tread wear. The only ones with 200 were the normal car tyres (eg. Silverstone Kruzer1). Could this tyre brand be another underdog just like the BC Racing coilovers? (Both made in Taiwan, both very good pricing for performance...)
Edited by TyresBro
I'd imagine if it is going to be for a daily car and not driving it hard around corners it should suffice.
If it meets DOT specifications - the tyre is safe enough for general use.
Just don't expect it to perform if you are an "enthusiastic" driver, ride quality may suffer too.
400 treadwear indicates very hard compound, which translates to poor grip. a higher number its not a good thing.
even the cheap nankang ns2 have a treadwear rating of 340.
^^^This is actually not totally correct.
The treadwear rating on a tyre doesnt indicate how hard or soft the compound is or how much grip the tyre can provide. The only way to judge how well a tyre grips is to use it and judge for yourself.
There are many different factors that determine a tyre's outright grip, like: tread design, tread depth, casing construction, silica or non silica. The tread compound isn't the only thing that gives a tyre it's grip.
Treadwear ratings are also highly affected by the depth of tread on the tyre... For example if a manufacturer made 2 tyres with exactly the same tread compound, design and casing but one had 5mm of tread and the other had 7mm of tread you would have almost the same performance from both tyres but completely different treadwear ratings.
To answer the original question about Hero tyres - they are manufactured by Federal as their tier 2 tyre, they share a lot of similarities in design and construction with Federal tyres and are comparable quality.
I have personally driven an R32 GTST Skyline on Hero Milanza HZ1's and found them to be very good tyres for their price.
The moral of the story? - Don't judge a book by it's cover.
I highly recommend them.
I use Hero Milanza HZ1 tires on my car.
FRONT- 235/45ZR17 97W XL
REAR- 245/40ZR17 92W
I've had them on the car for 20,000 km and there is still plenty of tread to last... actually the tread wear is still nowhere near the replacement marker.
I'm also pushing 250rwkw to which they hold traction fairly well. They're quite decent in the wet too, as long as I don't floor it...
If it helps here's the site for the tyres:
Silverstone Evol8 (Silverstone also makes racing tyres, in different section) (This is the sporty version of road tyres they offer)
http://www.silverstone.com.my/#1274413439156
Hero Milanza HZ1 (Doesn't have their own official site)
http://www.chapelcornertyres.com.au/hero.html
http://www.chapelcornertyres.com.au/files/DataMilanzaHZ1.pdf
Thinking of getting the Milanza HZ1s as daily drive and maybe some semi slicks for track use only :ninja:
EDIT: By the comparison of Hero Milanza HZ1 and Atlanta AR01, i might have gotten mixed up as the HZ1 is 260 tread wear and AR01 is 420 tread wear (both still road tyres).
Edited by TyresBro
  • 6 months later...
I've had the Hero HZ1 on my XR6 turbo for about five months and have done about 6000 km. The tyres are excellent and to be honest, I haven't noticed any difference between them and the original Dunlops in either the wet or dry. Great value for money. Highly recommeded.
Old topic but i have used hero's quite a few times on the back of my car. Similar grip to 595ss. I ran them at 28psi hot and at that they lasted relitively well! Basically on par with all the sub 100 $ tyres imo!
But it just sounds sooo nasty :(
My mate got some replacement tires on a car he was selling awhile ago...po young lol - couldn't even grip his 1st or 2nd in a 180kw wrx (so 4wd!).
And yeah...with your user name, i thought you'd be rolling around in re55s etc!
From what people are saying, it sounds like these hero tires are decentish though
  • 10 months later...
i've had Hero Hz-1's 235/ 40/ r18 Rears and 225/ 40/ R18 fronts on my r33 Si 4 door for over 6 months now and they are really good in the wet.
(I'm running HSD TT coilovers, however being that they are significantly softer ride than TIENS, as they are my base for comparison the tyres are fine.)
The HZ-1 are made by federal as they are a 595 copy.
In comparison to my brother who has 595 rs-r's on the front and 595's on the rear (of his r33 Sii 2 door) they are really twitchy in the wet. And his car is pretty much stock apart from Jap spec Teins.
Thats a good point I have had federal 595 tyres on my car before and they were awesome. I was hoping to go back to them. But since I made a alloy wheel change they didnt come in the size I needed.
Personally 595 would have been a better choice
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
