Hi,
This link was posted a while back by 'alexunder'. http://xenons30.com/reference.html
First link on that page is:
Model L20A, L24 Series Engine Service Manual- Complete 10.9MB PDF
It's an old manual but has pics of the timing chain and tensioner on several pages.
JH
Am I missing something here?
To me it doesn't matter a toss where the chain is mounted because the timing marks are on the sprokets, not the chain. The chain is simply the tool that connects the 2 (camshaft & crankshaft sprokets) together.
I'm using an Kameari hardened chain & Kameari adjustable chain tensioner and I can assure you, there is no shiny links in the Kameari chain whatsoever, not even the joiners.
And the timing marks must be set with the engine at TDC on #1 cylinder.
D
I think u might be im not sure? :bunny: have a look on the service manual in first quote, open service manual, scroll down to page 59, left column #17 and read the *note*
  • Replies 64
I think Ghostrider is in the same boat as me...
the shinny links are of no importance if the bottom and top are on TDC... I guess they just help you confirm that you have it set right, and I guess further down the track might help you know if the chain has slipped or something...
I think they are only important when assembling the engine without the timing case on, so you don't know for sure that the bottom is on TDC...
You don't need to change the castor rod brackets to adjust the caster, just make the current rods adjustable by cutting the thread longer and adding an extra nut...
Daewoo
ITS ALIVE!!!!!!!!!!!!!!!!!!!!!!!!
:(:D:O:banana:
:bunny: :bunny: :bunny: :bunny: :bunny:
sorry had too!
now ill have to do a oil flush with new oil/filter and prob do the auto at the same time
any reccommendations on oil but no castrol, etc crap?
also with the auto is there such a thing as filter replacement? similar to a vn's auto service kit?
gawd.... just go into repco and ask for the filter kit, its like under $30
oil, depends on the km of the engine, and what your plans are. ask the repco dude...
its ok getting everything ordered through workshop next door so everything will be done by Wednesday
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
