Hey guys i have a skyline r33 series 2 and i want to convert it into manual?? and how much would it cost roughly
i got a offer from someone for the whole conversion set for $1800 + clutch
Is it worth it or should i sell it and get a 180sx?
i am a p plater so i can't drive turbo but still want a quick drift car!
All answers would be helpful
Thanks
https://www.sau.com.au/forums/topic/320774-auto-to-manual-r33-s2/
Thanks
If your already thinking of selling I would put a bit of work into a cheap 180sx. The skyline NA's are worth heaps now thanks to p platers so you could get relly good money for it. Hell for about 4k you can buy a 180sx not in great condition but if you dont mind fixing it up, you could have both. And when your off your P's you wont have worry about the Auto to Manual conversion making it harder for you to sell it.
