i have a 93" R32 GTS-4 4 door and now have at home everything i need to convert my AUTO beast into a Manual Beast... gearbox, clutch, pedals, console parts, front and rear tailshafts... well you get the picture...
the guy i got the stuff off even gave me the manual computer on exchange for the auto one.
Now the only thing i'm worried about is the wiring difference between the auto box and the manual box. are the plugs the same or am i going to re-wire it all?
i know about the netural switch and the reverse lights. but are they any temp senders and 4WD stuff. if anyone knows i'm going to be doing the converision on the australia day weekend hopefully.
and another thing, how much and what size is the spiggot bearing i'll need for that goes onto the end of the crankshaft into the manual box?
Plugs should be the same. The 4WD computer is a separate unit (hides under the rear parcel shelf). Operation is hydraulic, from a reservoir in the RH boot. Keeping the air out of the ATTESSA system will probably be your biggest problem.
