My mechanic is not sure where to tap the vacuum of my Boost controller because the closer lines to the turbo are in metal and he don't want to cut these. He said it's better to have them the closer you can from the turbos.
Any thought??
Would this Tutorial for RB20DET work the same for the RB26 ??
http://forums.gtrcanada.com/gts-tech/t-how...ighlight=profec
Also,
Any thought??
Also,
I broke my valve unit harness on my profec2 and I can't find which wire goes where.
So, If you take the back of the unit in front of you. you will find the power harness and the vacuum to your left. Which wire is on the extreme right? white or green ?
Thanks a lot!!!
https://www.sau.com.au/forums/topic/320819-where-do-i-tap-my-profec2-on-rb26/
HIJACK!
I have realised that my bnr32 doesnt have the solenoid! Its been taken out and the two lines to it plugged up... Could definately be a reason it feels down on power - but my question is should I buy an original solenoid and put it in or just replace the original unit with a profec B???
Before someone makes comment, I do know that I wont be able to adjust the boost via a factory item (not really what I want at this stage anyway but will in the future).
u sure u dont have a boost tap of some sort controlling boost pressure?
sometimes there hidden or cable tied somewhere hard to see, have abit of a look around, especialy on the turbo side...
Edited by SiR_RB
HIJACK!
wellyou allready have the profec B, so you may aswell put that in now and just get the boost set to what you want it on now.then you can just turn it up latter when your ready,unless of course you want to buy a stock one,
So, i have to tap METAL LINES? there's no way to by-pass this!?
yeah you can just run all new boost lines. from the nipple on the plenum to the solenoid and then to a tee peice, from the tee to the 2 wastgate actuators,,, all new, you could take the other pipes off alltogether if you wanted. Oh and dont forget to block off the hose coming from the air connector- the dark blue pipe/hose on the diagram.
Edited by tuk32R
OK thanks for the info. I will be checking this saturday.
why do need to block of the blue hose in the diagram between the two wastegates ? mines still connected and seems to run/idle/boost perfectly !
If the blue line isnt blocked off you will have an air/vacume leak cause that joins to the inlet pipe from the airflow meter.So if im correct it will be sucking in unmetered air ,does that make sense?
the blue hose that goes into the inlet pipe between the 2 wastgates ? follow that around and it goes to the old boost control solenoid....thats not in use anymore so can it still get a pressure leak?
if thats the case il block it, got no probs with the car at all but might aswell do it lol
Edited by SiR_RB
Im not sure it can leak if still conected to the stock solenoid,if your cars runs fine it mustn"t leak, but it cant hurt to block it off..up to u i guess :D
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
