Dr30 Back Finally
Due to a comedy of errors finally got my DR30 back on the road after nearly 9 months.
Fitted a new turbo and intercooler setup and took the car to a recommended workshop to have the Autronics unit fitted.
After the car being pushed out of the workshop every day for 3 months and sitting on a bush block with virtually nothing being done I took the car off them.
Another workshop took the project on and it took them 4 month to get the car running.
I've now spent 12 hours reassembling the car (why can't mechanics put covers etc back on when they're finished) and cleaning the car to get her back to where I had her.
What a relief that there is no long term damage to the paint after vitually sitting out in the sun for 3 months over summer.
On a more positive note the car drives great with 220rwhp which is a lot more than it had previously.
The tuner says the injectors are maxed out so changing them would net me a lot more power :banana:
I'll consider that but want to just enjoy the car for a while.
Missus thinks I have too many toys and wants me to sell to spend on and make room for my R33 GTR
3 cars and a Motorbike into a 2 1/2 car garage don't go :ermm:
Yes I love the DR
Cost me way more than I'd get for her at the moment and I still have a "to do " list.
Fitted lower springs and she's still sitting at stock height.
So that has to be sorted next week
Can anyone suggest what injectors are interchangeable on the FJ20?
Tuner says I've maxed them out @ 220hp
OK thanks
One thing that was annoying me was that my car had a few pin dents in the rear guard and tops of the front guards.
Just got back from the dentmaster guy and I'm impressed!! Those guys are magicians.
Car looks fantastic
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
