Just wondering if any of you guys know anyone that could hook me up with the future defects i may get lmaooo..
A mate of mine got defected in his 180 and he had to switch everything back to stock almost :P.. ill hate to have to do that to mine :(..
Is there anyway around this or would i just have to bite the bullet? haha
Also,, my membership form is all filled out :ermm:.. posting it tomorrow :banana:.
https://www.sau.com.au/forums/topic/320828-defects/
Well you'll get defected for that GT3076, the PowerFC, the bleed valve, your aftermarket exhaust with de-cat pipe, aftermarket suspension with cut springs. Of course I'm just assuming you have all this stuff because you didn't give us an idea of what you have before asking what you'll get defected for. Let me consult my crystal ball :thumbsup:
Unless "hook me up with the future defects I may get" refers to some sort of Minority Report style of crime and punishment, whereby you would like someone to based on your mentality for future modifications alone.
Or should that line refer to where you can get the parts you plan on being defected for - well, anywhere - just go through the trader forums on here for some high quality defectable items delivered promptly to your door.
Almost any major modification you do to your car is defectable. Trick is to read the EPA laws and your relevant state laws. Abide by them or go under the cloak and make things look stock.
https://www.sau.com.au/forums/topic/320828-defects/#findComment-5237240
...and the writing more illegible :D
and write things for no reason.... stock exhaust to loud lol then put Nissan "CAR" because he dosent know what it is and some how think its white in colour instead of silver :cool:
i lol'd at my defect seem's he has never seen an R33 4 door lol
https://www.sau.com.au/forums/topic/320828-defects/#findComment-5242310
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
