Just wondering if any of you guys know anyone that could hook me up with the future defects i may get lmaooo..
A mate of mine got defected in his 180 and he had to switch everything back to stock almost :P.. ill hate to have to do that to mine :(..
Is there anyway around this or would i just have to bite the bullet? haha
Also,, my membership form is all filled out :ermm:.. posting it tomorrow :banana:.
https://www.sau.com.au/forums/topic/320828-defects/
Well you'll get defected for that GT3076, the PowerFC, the bleed valve, your aftermarket exhaust with de-cat pipe, aftermarket suspension with cut springs. Of course I'm just assuming you have all this stuff because you didn't give us an idea of what you have before asking what you'll get defected for. Let me consult my crystal ball :thumbsup:
Unless "hook me up with the future defects I may get" refers to some sort of Minority Report style of crime and punishment, whereby you would like someone to based on your mentality for future modifications alone.
Or should that line refer to where you can get the parts you plan on being defected for - well, anywhere - just go through the trader forums on here for some high quality defectable items delivered promptly to your door.
Almost any major modification you do to your car is defectable. Trick is to read the EPA laws and your relevant state laws. Abide by them or go under the cloak and make things look stock.
https://www.sau.com.au/forums/topic/320828-defects/#findComment-5237240
...and the writing more illegible :D
and write things for no reason.... stock exhaust to loud lol then put Nissan "CAR" because he dosent know what it is and some how think its white in colour instead of silver :cool:
i lol'd at my defect seem's he has never seen an R33 4 door lol
https://www.sau.com.au/forums/topic/320828-defects/#findComment-5242310
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a one-time tool to do something, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
    • The switch part, is the switch you use to turn the lights on and off in the car.   The test I had was to determine where in the line it is, but on a quick rethink, if it's only blowing when you turn the switch on, then it's the wire from the switch, to the headlight that's got the short. Now it's a case as GTS said, of physically finding the fault. The fault could be:  metal has broken through the loom. Known as a rub through. Places to check: anywhere the wiring has been messed with in the car, particularly firewall grommets if extra cables have been passed through. Check the inner guard linings, you might be rubbing through with a wheel, particularly if the vehicle has been lowered. Also check for anywhere there could be high heat, especially if heat shields are missing. Double check any wiring at the head unit too if someone has messed with the headlight wiring to pick up a feed to dim the headlight at night. You could also just have really old cabling that is literally falling apart, though, this is more likely in Euros than in an old Nissan in my experience.
    • Yeah. I usually go by the torque specs. I forgot that Nissan recommends 1386b sealant on that thread, still can buy it on ebay actually.
    • Umm.... He attached it to his 2021 update post. Don't need the link. It is stored on the forum.
