  • Replies 104
You know, sitting on the roof like that can put a rather large dent in it... :P
(not that Im complaining about the photo though).
I have a new photo for you from World Time Attack :mad:
(hopefully you can see the fb link).
Washed my car friday night, now its dusty as Fk from wakefield, and has a permanent miss when its hot. Not happy Jan
Haha yeah mine is FILTHY from being parked up there all day. It's getting detailed in a week so should be nice and shiny for the dyno day :(
only if its pink, cooler colours dont work for me
+ do you really wants it back :rofl:
HAHAHAHA I bought fluro green Borat man-kinis back for Mark and me from Thailand in February. Michele wants us to wear them when we're pitcrew for her at races but for some reason it hasn't happened yet :)
* Melly *
+ do you really wants it back :rofl2:
I think I have a pink one I don't wear anymore lol :P
HAHAHAHA I bought fluro green Borat man-kinis back for Mark and me from Thailand in February. Michele wants us to wear them when we're pitcrew for her at races but for some reason it hasn't happened yet :D
Haha!! Do it!!
Hows this for eye candy?
I think I threw up a little bit
Hit a few bugs near mildura on my way back from adelaide last month
Did this trip recently, the white Commodore looked just like that. The bugs are f**king HUGE! In fact they're not even bugs, they're like locusty things :P
I like my insurance company so much I park IN the office :P
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
