I had my R33 broken into on the 2nd of Jan in Melbourne CBD, they seemed to know exactly how to get in as the actual lock wasn't touched, they used a method that I won't go into as I don't want to help others do the same. They stole my stereo and amp, luckily neither were worth very much, but to get the stereo out they did break the dash board.
Any last night I was at Melb High and there was another R33 Skyline which I noticed had the same markings on it that indicated it had been broken into in the same fashion and looking in the window it was also missing its Stereo.
So using my powers of deduction I'm tipping that these two aren't isolated cases, has anyone else had their skyline broken into recently in Melb.
I'm sure there must be a way to stop how they are getting into the car, if anyone knows what I am talking about and has already figured out how to prevent it can they please PM me. An alarm doesn't seem to stop them.
https://www.sau.com.au/forums/topic/32087-skylines-in-melb-being-broken-into/
  • Replies 114
JAPCAB has the same thing happen to him in the city near the childrens hospital. They also took the stereo, and broke in through the left siee door lock. Id advise everyone to have a 'microwave radar sensor' in there alarm, that way if any sort of motion is detected in the car it will release the ear piercing signal and deter thiefs. This technology is used in convertibles when left open. But work great in closed enviroments too.
also.. if anyone catches the theif that is on this rampage, PM, ill be right over to break this ****suckers nose.
Thanks.
    • Sane enough. Remove the roof liner, because the acid will go everywhere.
    • Thanks guys, I really appreciate the help and experienced opinions.  I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here;  I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes.  Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner.  Does that sound sane? Is one type of filler better than others for this?
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
