Hi all trying to rule out all other possibilities on why my gtr is blowing bluey grey smoke. At the moment all signs are pointing to the 18 month old hi flowed turbo's. How ever before forking out the $2400 for my 2860-5's i want to check that it could be a simple thing as the pvc valve or blow by valve as some people call it. Where is it located on the rb26 is in on the inlet side of the head connected to the tappet covers and it should be able to be blown through one way only if i am correct ?. I can rule out valve stems seals to a certain extant to the amount of oil in the turbo compressor housing and as valve steams would leak directly into the combustion camber. I will be doing a compression test tomorrow night to make sure it is not excessive blow by as well due to worn piston rings from the previous owner being a moron and driving the car for so long on a run in tune. Any other ideas or checks that people can think to do would be appreciated.
cheers scottie
https://www.sau.com.au/forums/topic/320879-turbo-oil-seal/
cheers scottie
yep the pc valve is a one way valve,its located on the inlet side,,,
https://www.sau.com.au/forums/topic/320879-turbo-oil-seal/#findComment-5236665
  • 5 months later...
LOL Yeah not good lol, compression was down across the board and ended up being a complete rebuild :) had really bad scoring on 1 and 6 bores coursing massive blow by but it was funny no oil came through the catch can :( . How ever $13 000 later it is being put back together this week by paul at red r racing. I ended up going pretty much all out new turbos, cams, cam gears, extended sump, hks oil pump and new injectors, ross harmonic balancer, new bearnings rings ect. Also got a new clutch because the old one was almost on rivets. So if it dont go hard and put a smile on my face i am gonna burn it lol
https://www.sau.com.au/forums/topic/320879-turbo-oil-seal/#findComment-5513770
lol i just found out after pulling the dumps off my old turbo one is completely rooted ey i have never seen a turbo with some much end float and it just started touching on the housing as well luckly i have done everything, I probley could have been fine with a turbo change and it could have lasted awhile longer but what done is done.
$13 000 i think is a pretty bloody good price since crd wanted $9000 for the engine alone if my block was good which it wasnt lol and it didnt come with a extended sump, upgraded valve springs, injectors, turbos, clutch and everything so i am pretty lucky and i had another mob wanted $10 000 for a stock rebuild.
I went for a single plate jim berry clutch the pressure plate has 3500lbs of clamping pressure and the clutch plate has some big ass dampener springs in.
https://www.sau.com.au/forums/topic/320879-turbo-oil-seal/#findComment-5514967
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
