hi guy's,
im putting my cressy up for grab's because another car has come up that i want to jump on...
its been a good car and rarly get's driven" i have gf's car as a daily"
rego: FEB 2011
314,000km's on chassis
approx 150,000 on engine.
engine:
full jzx81 motor with new toyota front sump fitted
2jz waterpump and housing been done"has to be done to run without the gay viscious"
steel wheel ct12 turbo's fitted "running 12psi"
various heatsheild's etc have been ceramic coated
custom dump pipe's into twin cat's and twin muffler's
front mount with custom pipe work to suit
boost/fuel cut defendor installed
larger intake fuel pump
trans/driveline and suspension:
a340e tran's with mv automatic's stage 1 kit
newish bilstien shock's with custom spring's "sitting approx 1inch lower then std"
whiteline custom front and rear sway bar's
grande lsd with custom strengthend rear subframe and larger diamter diff mount bush's installed
jzx81 steering rack fitted "more lock"
jzx81 crossmember and associated suspension
jzx81 strut tower to firewall strut brace.
brake's/wheel's:
ba ford front rotor's with nissan 4 piston caliper's
slotted rear's
bendix pad's all-round
all caliper's rebuilt
17" is200 wheel's with near new front tyre's
interior
immac beside's c-pillar trim's
newish sterio fitted "i-pod/usb aswell as bluetooth headunit"
cold air con! however the heater literaly just stopped working "2 day's ago"
aftermarket tempreture gauge fitted "std not wired up"
speedo has been recalibrated aswell as the tachometer
outside the car is also good however there is a few mark's etc on it
bootlid is faded etc
tow bar fitted
serviced literaly once a month as i get oil's for free
timming belt/water pump,spark plug's and its also running twin fuel filter's
radiator reccently reco'ed and toyota red longlife coolant added
previous owner has taken it to wsid and did a 13.0
most importantly ZERO police attention! we all know how valuable this is these days.
HOWEVER the car is engineerd incase you should be hassled
under the bonnet is stdish looking "comodore airbox etc"
perfect daily with abit of poke!
located in hornsby
$8000 neg
i am open to trade's however prefure cash as i have a car in my mind
i am also willing to neg for a REASONABLE amount..
prefure contact via pm
https://www.sau.com.au/forums/topic/320904-1jz-powerd-mx83-cressida/
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
