Last night I decided to service my car. In the process of undoing the sump plug, I rounded it to the point I can't.
Tried plumber's stilsons, hoping the teeth would grip it but to no avail.
Filed back the head to square. Had a thought of hacksawing the head and using a large blade screwdriver but the bolt seems to be a fairly soft metal.
Anyone got any ideas from here?
https://www.sau.com.au/forums/topic/320914-rounded-my-sump-plug/
drill through the plug n get a new bolt? lol
get a smaller size socket that you dont need to buy a cheapo one and bash it onto the sump plug and undo it. did the same wheni had my R33. was the only way to get it out. or as mentioned above drillit out but just be carefull you dont f**k the threads up ont he sump
^ Yep smaller socket
or
Easy out - one of those mobile people that get manifold studs out of the head (Thread Doctor), should be able to do it.
They are quite reasonable priced if thats what it comes too (couple hundred or less)
get a better pair of vice grips.. if there is still a head on the nut, regardless if its rounded, jam some vice grips on there but do them up soo tight that its almost hard to get them to clamp, after this your better of knocking the vice clamps with a hammer (leftie loosie rightie tightie), than trying to undo them with your hands as the impact will have a better effect..
if you can't undo them with this, which i find hard to believe then get someone to weld a bar on there, if your doing it right it'll either come out or your'll snap the head off the bolt, if this happens i wouldn't bother with an easy out as its well and properly stuck all you'll end up doing is snapping the easy then its just a bigger pain in ass..
next step work out what size its meant to be and drill and re-tap the thread..
good luck
i remember that sparkplug thread. some guy got work done at a workshop, and came home to find that. shocker!!
oh yeah. vice grips would be my first step. super tight. you may even need multigrips to close the vice grips :thumbsup:
Edited by Munkyb0y
Amen to vicegrips. These suckers are so great with bolts and no sump plug on any engine should be too tight for vice grips. If it is, then the person who put the sump plug back in did an awful job of it!
Don't think I have to tell you to use a new sump plug and washer afterwards lol.
Thanks for all the advice guys. I did think of the tack weld, but looked around and no welder.
I might go with the smaller cheapo socket + hammer.
The spark plug is a great idea, but might drop my road clearance belong 100mm. :)
or
A COUPLE OF HUNDRED??!! How is that reasonable Ash?
sif a sump wouldnt be cheaper?
....or get a file and file the nut to a smaller socket size, at least this way no drilling, no bashing, no vicegrip.....involve and you could actually use it again.
Yeah just file it flat on opposite sides and use a big shifter spanner ... don't know about using it again though!
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
    • Is there an actual website thingie for peoples who don't have Facebooks? Cheers
    • All Jap Day is coming up again! 13th of July this year. Are you going? Tickets go on sale on Wednesday 6pm. Please let Quang know as well. https://m.facebook.com/photo.php?fbid=1163155775853542   I still get shit from my wife for this photo because it is the happiest she has ever seen me. And it's not with her, it's in someone else's car.   Quang's EVO is sick, but that rotary wagon flying past was absolutely bonkers.
