Hi guys,
Picked up an RB30 block and crank on the weekend (cheers pnk32). Block has water and oil lines already tapped - awesome . :D
Now, I think the bore is 87mm (I didn't have a ruler handy, but the play between piston & bore was greater than in the RB25 block). I'll measure it properly today to be sure... BUT the cylinder wall has rust spots etc, they don't look deep or anything but it'll definitely need a cleanup.
Anyone know a good place in BNE to get block (and possibly head as well) cleaned up? It would be great if said place will do bore machining/honing and possibly even re-sleeving if necessary.
If the bore can be machined to clean up the rust etc... how MUCH can be machined off the surface without going too far past the 87mm mark? Is it just a matter of getting piston ring gaps right when doing the build? Or am I better off punching the sleeves out and getting them re-done (can you even do that on an RB30?) If I do get it resleeved, can I go even bigger bore than 87mm (and still find pistons to suit)?
Sorry if I've repeated any questions that have already been asked.
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
