My 040 was loud as f**k harts
and then again it was vapourizing fuel to the point were I had to crawl it home from the hills to the bay,so I pulled it out and went back to stock
fuel was so hot in the tank by the time I got it home I could hardly bear putting my hand in there to pull the cradle out
been talking to Adam bout all this
he knows what he needs to do in regards to budget and process
^^^ something was wrong then lol
i wouldn't choose anything besides an 040 personally
and they aren't stupid noisy if you insulate them from the cradle - that's why there is rubber stuff between the pump and cradle with OEM setup
Still confused here lol, I've got a set of injectors sourced, daka 550s need sum plugs for $60 but will cost my less than 400... I'll hunt for a good deal on fuel pump slowly... Doubt I'd notice the pump with my zorst!!
Spoke to hypergear, 960 for the hiflow, said my stock actuator will hate life after 15 psi, and should look at a wastegate controller??? WTF is this? Said he can sort these issues for an extra $200... What's the story here...
And what's this about lines not matching up
with hypergear??? They arnt touching them r they??
under $400 for a set of 550's is a really good find. i'd agree with hypergear about the wastegate actuator not coping too well above 15psi, thats over 3 times the level it was designed for, 5psi. wastegate controller?, maybe they mean to get a new wastegate actuator from them, it make sense for the price. i had to get one for my turbo upgrade and it set me back about $185, so not far off $200.
don't know about the lines though. you'd think if they where taking your turbo and highflowing it, it should bolt back up easy?? is that what hypergear said?
another thing that may be an issue depending on you target power level, is the AFM. if only around the 220kw mark to start with you might get away with leaving it till after everything else is installed. then when you go in for the tune just ask the tuner how close to the stock AFM's limits your getting. then you'll know for sure if it needs to be upgraded.
and just a couple things that happened to me with my upgrade. when installing new injectors i didn't want to split the plenum to get to the fuel rail, you can do the swap without splitting it but there is very limited space to pull the fuel rail back off the injectors. you should be able to get it back just far enough to do the swap though, i found it tricky but doable. i just removed as much of the small bits that are in the way as i could e.g throttle body, fuel lines iacv line etc.
my stock BOV started failing (blowing off during acceleration) at boost pressures of 14-15psi. had to source and aftermarket plumb back. blocking it off was bad, constant stalling and backfiring.
and at the moment i don't have a shift kit for the auto (happeing very soon :D ), my stock auto box doesn't like the extra power during full throttle gear changes. i have to back off to half throttle to let the auto grab the next gear before planting it again, it gets very annoying lol.
Take your wastegate actuator off and take it to bill at Ats,he will cut it and thread it With a fitting on the end,so that's it's completely adjustable
that's what I did and it's 40bucks and takes 10minutes
damn, $240/hr :)
40 bucks for an adjustable wastegate and a free chat with bill for advice and pointers is better than 200bucks for an actuator in my book
bill is the turbo messiah in Adelaide
I rang him to ask about the Rb20 actuators,he said you mite get lucky and get one with a tight spring,and if you get one with a sloppy spring,it's useless and not easily replaceable
so ive ordered a walbro gss342 fuel pump... havnt got it yet ... but can someone quickly run me threw the instalation.
ive spoken to rodders about it and hes keep to give me a hand... it comes with a 32 33 34 mounting bracket aswell :D nb for 118 new!....
im going to look at this constant wire up thingo ive been hearing about... can someone lead me down the right path there
also im looking at z32 afm and ive come across a cop tail plug for the z32... it says its good for a 31 s14 silvias 180 32... is this going to work?? or is there a specific rb25 plug?
im guessing the going rate is around the 200 mark for plug and afm?
You need to
1. try using the search function
2. read the diy in the stagea section and also the skyline section.
You will find things like:
http://www.skylinesaustralia.com/forums/Z3...=z32+afm+wiring
and (for stagea remove spare wheel cover and the floor panel to its right):
http://www.skylinesaustralia.com/forums/To...mp-t253097.html
(walbro is simpler but you get the idea)
  • 1 month later...
so... just wondering if you guys can think of anything i may be missing bout to get my tune...
255lph walbro fuel pump
HKS 2535 turbo adj actuator
z32 afm
pod with solid intake
3" strait threw zorst
profec b spec 2 EBC
advan fmic
620cc siemens deka injectors
100% plumb back turbosmart Kompact BOV
shift kit
will be tuned with nisstune
there no point doing an exhaust manifold is there??
also going to do a better radiator i think and a bigger trans cooler...
looks like you've got it all sorted. assuming your coilpacks are in good working order i'd just throw in a new set of spark plugs before sending it to get tuned. stock exhaust manifold will be good enough for the turbo you have chosen.
Adam what about Transfilter ,a remote OIL FILTER KIT ,same as Engine Oil set up but Trans oil ,Good luck ,
Cheer`s Chuckie.
is this really a worth mod tho??
think i made a good choise with the turbo... i do a bit of towing and 100% street driving... so nice bit of pick up :banana: and good re sale :ermm:
yeah am going to do that... get my .8 on :).... coil packs are fine at the moment... its not going to change anything if i change them after the tune tho is it?
Edited by chef_stagea
think i made a good choise with the turbo... i do a bit of towing and 100% street driving... so nice bit of pick up :P and good re sale :D
yeah am going to do that... get my .8 on :D .... coil packs are fine at the moment... its not going to change anything if i change them after the tune tho is it?
Well i think so as ANY FILTER ON OIL is a GREAT THING to have,& will help with TOWING,
As there`s no Filter on them,
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
