We urgently need Wayne Prenter to PM his address to any SAUNSW club exec
His Superlap tickets are waiting here and we have not got your address here to send them to.
If you have given it to me or someone else in the club i apoligise but we need it again.
If you forgot to give it to a club exec, here's your not so subtle reminder :thumbsup:
If anyone knows Wayne, would you please alert him to this thread asap
Thanks
https://www.sau.com.au/forums/topic/320948-wayne-prenter/
