Bonnet and hinges $165
Bonnet dampers $60
Guards L & R $110 (Passenger guard has a ding near the headlight)
The long metal parts the guards bolt to in the engine bay L & R $30
High beam L & R $75 each
Front bar $40 (Has a small crack near the passengers headlight can be welded, and the usual small scratch's)
Reo $50
Bonnet catch and support $60
Stockintake pipe with stock oil and BOV return pipes $40
Stock side mount with return piping $50
LHS passenger door COMPLETE, $90 (door skin is toast though)
$570 for the lot!!! (excluding postage and packing fee if going interstate)
Power steering reservoir $10 (can be used in pretty much any skyline though I think)
Auto trans cooler $15 (average cond)
Washer bottle with motors $20
Condensor $15
Stock horns $10
$40 for the lot!!! (excluding postage)
S15, came off at 60,000km's
Stock camber, traction and toe arms $40
Stock side mount with most if not all piping $50
Stock DIN pocket, hole cut in back for EBC wiring $20
Stock A pillar Garnish (no gauge cup) $30
$90 for the lot!!! (excluding postage)
Not a prob....
On another note, I'm going to put whats left onto fleebay... so if you think you might want or need something let me know and offer a price and lets see what happens. I need to get on with the backyard reno's
  • 1 month later...
Not a prob....
Paid for washer bottle well over a month ago and still its not arrived. Have sent messages and no reply. :D
  • 1 month later...
  • 3 months later...
Bonnet and hinges $165 NOW $120
Bonnet dampers $60 NOW $40
Guards L & R (Passenger guard has a ding near the headlight) $110 NOW $85
The long metal parts the guards bolt to in the engine bay L & R $30 NOW $25
High beam L & R $75 each NOW $105 FOR BOTH!
Grille with badges $60
Front bar (Has a small crack near the passengers headlight can be welded, and the usual small scratch's) $40
Reo $50
Indicators and foglights (front bar) L & R $25 each (Plugs have been removed but can still be wired up)
Bonnet catch and support $60 NOW $30
Stock airbox with panel filter and snorkel $80 NOW $70
Stockintake pipe with stock oil and BOV return pipes $40 NOW $25
Stock side mount with return piping $50!
LHS passenger door COMPLETE, bit dusty. Glass locks etc all perferct (door skin is toast though) $90!
Stock BOV $20 NOW $15
I'm at work quite alot of late and cant really answer the phone so please PM or txt me on 0409077592. Cheers
  • 1 month later...
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
