Bonnet and hinges $165
Bonnet dampers $60
Guards L & R $110 (Passenger guard has a ding near the headlight)
The long metal parts the guards bolt to in the engine bay L & R $30
High beam L & R $75 each
Front bar $40 (Has a small crack near the passengers headlight can be welded, and the usual small scratch's)
Reo $50
Bonnet catch and support $60
Stockintake pipe with stock oil and BOV return pipes $40
Stock side mount with return piping $50
LHS passenger door COMPLETE, $90 (door skin is toast though)
$570 for the lot!!! (excluding postage and packing fee if going interstate)
Power steering reservoir $10 (can be used in pretty much any skyline though I think)
Auto trans cooler $15 (average cond)
Washer bottle with motors $20
Condensor $15
Stock horns $10
$40 for the lot!!! (excluding postage)
S15, came off at 60,000km's
Stock camber, traction and toe arms $40
Stock side mount with most if not all piping $50
Stock DIN pocket, hole cut in back for EBC wiring $20
Stock A pillar Garnish (no gauge cup) $30
$90 for the lot!!! (excluding postage)
Not a prob....
On another note, I'm going to put whats left onto fleebay... so if you think you might want or need something let me know and offer a price and lets see what happens. I need to get on with the backyard reno's
  • 1 month later...
Not a prob....
Paid for washer bottle well over a month ago and still its not arrived. Have sent messages and no reply. :D
  • 1 month later...
  • 3 months later...
Bonnet and hinges $165 NOW $120
Bonnet dampers $60 NOW $40
Guards L & R (Passenger guard has a ding near the headlight) $110 NOW $85
The long metal parts the guards bolt to in the engine bay L & R $30 NOW $25
High beam L & R $75 each NOW $105 FOR BOTH!
Grille with badges $60
Front bar (Has a small crack near the passengers headlight can be welded, and the usual small scratch's) $40
Reo $50
Indicators and foglights (front bar) L & R $25 each (Plugs have been removed but can still be wired up)
Bonnet catch and support $60 NOW $30
Stock airbox with panel filter and snorkel $80 NOW $70
Stockintake pipe with stock oil and BOV return pipes $40 NOW $25
Stock side mount with return piping $50!
LHS passenger door COMPLETE, bit dusty. Glass locks etc all perferct (door skin is toast though) $90!
Stock BOV $20 NOW $15
I'm at work quite alot of late and cant really answer the phone so please PM or txt me on 0409077592. Cheers
  • 1 month later...
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
