d-jetro will run map sensor but you have to use the GTR one so u lose vct and its a bit of a pain and not really worth it unless your going for big power
U can tune out the effects of atmo bov by altering the map yes.... but put a plumback on, there way less hassle. If your sick of the stock plumback theres quite a few aftermarket plumbacks
https://www.sau.com.au/forums/topic/320968-powerfc-tune/#findComment-5237864
The D-Jetro versions tune using MAP, but are more expensive than the standard Power FC.
Just use a plumb-back with a pod filter, will still give you something of an atmospheric sound.
https://www.sau.com.au/forums/topic/320968-powerfc-tune/#findComment-5237867
If it came with a jap tune id get it re-tuned asap
Japs run much nicer fuel then us so the tune will probably be fairly average on Aus fuel
You can get the BOV to work properly with the power FC so if thats easier and your happy with it should all be good. Might just be a bit of fiddling around for the tuner at idle and low revs but no dramas really
https://www.sau.com.au/forums/topic/320968-powerfc-tune/#findComment-5238185
There is no real way to satisfactorly tune a power fc or any other AFM ecu with an atmo BOV, the BOV just adds way too many variables into the metering equation. too tight and the reversion effects the afm, too loose and they bleed boost which effects mixtures.
https://www.sau.com.au/forums/topic/320968-powerfc-tune/#findComment-5238205
ok, thanks for the info. I might go with an aftermarket plumb back if this doesnt work out for me.
The jap tune might also explain why the engine light comes on at full throttle and boost around 6k rpm. Got a retune booked for thursday.
Edited by ZXY
https://www.sau.com.au/forums/topic/320968-powerfc-tune/#findComment-5238266
a good tuner can tune out the stalling effects from an atmo bov in either ljetro (airflow meter) or djetro (map sensor) for any given ecu if they know what they are doing, the powerfc is the same
its a bandaid fix, but it's certainly something the tuner can do (with experience)
https://www.sau.com.au/forums/topic/320968-powerfc-tune/#findComment-5238347
im not getting any stalling effects at all, but i notice its running rich from soot on my back bumper. and i have engine light coming on near redline which is probably due to bad tune.
https://www.sau.com.au/forums/topic/320968-powerfc-tune/#findComment-5238375
the engine light is most likely the knock warning. by default it flashes the engine light when theres any knock over 60. do you have a hand controller?
best to keep it under 5-6k if its flashing above that, until its tuned
https://www.sau.com.au/forums/topic/320968-powerfc-tune/#findComment-5238404
yes i have a hand controller. I will check out the knocking when i get home on wednesday. The car wont be driven until it is tuned.
https://www.sau.com.au/forums/topic/320968-powerfc-tune/#findComment-5238440
RTFM.
Paul gave you good advice. why don't you do what he says?
you are right, its not knocking...
at normal driving 7 knocking
at 0.71 bar rpm 4k 7 knocking
0.8 bar 6k rpm 15 knocking
30 knocking max achieved.
has to be something else...any ideas?
https://www.sau.com.au/forums/topic/320968-powerfc-tune/#findComment-5239154
:D
for those who cant be bothered reading
the engine check light comes on and flashes differently for the following reasons
a sensor out of range or failed - ie water temp sensor, airflow meter, tps - which ever is dead will be highlighted in ETC, SENSOR SW CHECK on the hand controller
injectors reaching 98%
knock exceeding a level of 60
airflow meter reaching 5v
these are defaults on the powerfc and you can change the sequence flash in datalgot, and you can enable/disable the flash on the hand controller via ETC, FUNCTION SELECT
https://www.sau.com.au/forums/topic/320968-powerfc-tune/#findComment-5239307
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
