question for the engine builders and knowledgable..
just recently brought a GTR with built RB28, first time we put it on the dyno it split a wastegate hose and hit boost cut at over 30psi, now there is a tiny oil leak under the exhaust manifold between the head and block, been told its probibly stretched the head studs and we need to remove head to replace studs and get head checked etc etc
Excuse my ignorance for knowing f### all, but can't the head just be re-torqued ???? car still runs perfectly
If the above is needed, how would I expect to pay ?
https://www.sau.com.au/forums/topic/320996-stretch-head-studs/
I'm no engine builder, but you'd want your head studs to be as top spec as possible. They're not THAT expensive, after all you don't want be cruising down the road and pop a head gasket, then have to fork out more to rip the head off, just cos you skimped out on the studs...
I say if they are in anyway damaged at all, replace them. Who knows, they might just need re-torquing, but i doubt it if the head has lifted enough to cause a leak. I'm surprised you didn't damage the bottom end at all, if boost was that high, how didn't you get heaps of detonation and end up with killed pistons?
Sorry to answer a question with a question, but why wasn't the boost monitored? i.e. surely the tuner saw that the boost was increasing out of sight, why didn't he stop the run when boost was spiking out of control?
Don't apologize man! That's what this forum's about!
just got off the phone from the workshop, after a more thorough inspection they are leaning towards a wrongly machined block or head , slightly to much removed on the outside of the oil gallery that feeds the head....only the smallest leak atm, not to many options with this one, not far off a full rebuild, pretty piss poor, engine has done less than 5000km and cost the previous owner over $50k
we're going to try chemi-weld or something similar as a patch, ( because I only just bought the car and can't afford a rebuild straight away :)
very pissed off
What turbo/s?
HKS step2 2.8 stroker, full counter crank and rods kit, CP pistons.
Brand new head from Nissan, Jun 272 in and ex cams, 10.8mm(?) lift, special retainers and all the jazz needed to support the cams and high revs, heads extensively ported.
Big dollar hypertune plenum and single throttle body setup
Custom alloy breather tank etc
Jun oil pump, N1 water pump, cant recall the brand of balancer, but its a good one.
Trust sump extension.
Turbonetics GTK-850 turbo and big Turbonetics external gate
What head gasket, MLS or copper ?...i have seen copper head gaskets needing a re-torque.
You shouldnt see this normally with a good mls though.
I'm not sure, I'll be ring the mechanic who built it tomorrow, I would think judging by the rest of the build, it would be a good one, doesn't appear to have skimped anywhere else..
The whole thing souds like a bit of a crock from the info you have provided.
Not from you personally but from the 'workshop'.
Stands out like dogs nuts...can't understand why the king of RB engineering ^ didn't pick it up instantly.
I build these engines all the time and i have a fair idea what has happened. Was it built locally?
Edited by Swiper the Fox
it was built in adelaide , I'm in perth..
please elaborate on whats happened
Ok..for a start there are NO oil feeds to the head on the exhaust side of the engine...so that statement they made to you is incorrect.
It was built using a fastner when correctly installed that can generate a maximum clamping force of 220,000psi under operating conditions below its yield strength.
The engine only saw 30psi of boost!...stretching a 12mm main stud takes a bit more than that.
My guess is one of these...incorrectly installed stud...probably bottomed out or incorrectly torqued , poorly cleaned head that has leaked oil onto the head gasket during installation compromising the seal or the block is split around the turbo oil feed.
thanks for your help..althou none of those options sound good ..
cheers
cheers
just something to compare...i knocked up an engine from mostly used parts for my wife so she had a decent engine to race at the drags. It had 2nd hand Nissan head bolts and stock head gasket...
It was thrashed for over 3 years and won about a dozen trophys and made 465+awkw at around 35psi of boost!
Id never recommend anyone ever actually do this but it goes to show it not the sum of the parts used...its how they are put together that really counts the most.
boy aint that the truth
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
