Hi All,
I know this one appears in the 2010 events list but I thought i'd put a thread up to remind everyone.
Eastern Creek Open Day - 28th May - It's a Friday
Cost os $125 or $95 for ADRC members. Must have an L2S licence or above. Gates open at 7, track opens at 9am and closes at 5pm.
To ensure quick sign on, fill out the form in this link and bring it with you. - http://www.eastern-creek-raceway.com/pdf/I..._Disclaimer.pdf
I would have loved to go but I can't make this day but let me know if anyone has any questions.
Liz.
Hi, is this event still going ahead?
This is held by Eastern Creek, anyone with an L2S licence can rock up on the day to go fast! Chances of it falling over are minimal, but if you are paranoid just give them a ring (9672 1000)
I should be making an appearance around 1330 :P
I should be making an appearance around 1330 :(
i think he means is it still going ahead as in, is it still an open day
they recommend you check a couple of days in advance just to make sure it hasn't been canned.
I'll call tomorrow boys.
turned out to be a excellent day.
Not so much for the car though. The front right tyre delaminated just at the end of my last session so I had to drive home with the craziest vibration ever. Lumps of rubber falling off everywhere! I thpught about throwing on the limp-home but I just crawled home. Turbo is now making a funny noise :)
Thousands. It was pretty packed. Not many 100% hotlaps which was really the only downside. One minute I was being smoked by r35gtr's the next your trying to find your way around old school escorts with grumpy drivers who won't let you pass :)
Yeah it was packed because they had Australian GT cup practice on that day for the race meetings overs the weekend. Instead of having the usual CARS, BIKES and L2S sessions, they had:
1) OPEN WHEELERS,
2) CARS (ppl who have a race licence),
3) AUS GT CARS,
4) BIKES, and then,
5) L2S.
So very few sessions. I only did two full sessions and one 5 min one due to some one coming off and I struggled with tyre temps and grip throughout all of them. It was still pretty cool though, to watch Lambo's, vipers, porsches and Corvettes going around...
FloydWest, were u in the black r33 GTS-T with a carbon/vented bonnet?
yeah that was me.
I struggled with grip too. Came off twice at turn 4 and once coming out of turn 2.
Well, I blame grip - but it's most likely my terrible driving skills.
How many sessions did u do? I only remember being on the track with you for the 2nd last session of the day (i.e. the 3:10pm one, i didn't stay for the last one).
Is your car ok? You were saying that the turbo is making weird noises now?
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
