- hey got an rb20det engine of my r32 that i was stripping, was in real good condition ran fine etc.. has around 140,000km on dash
$1000ono
- also got the auto gearbox for it
$450ono
- turbo with dump pipe
$220ono
- brand new front rotors, were on the car for about a week or so
$140ono
- front pipe
$60
- crossmember with new gearbox mount
$80
also got all these other parts that i was stripping off my skyline which can be found in this thread:
http://www.skylinesaustralia.com/forums/St....html&st=40
pm on here or message me on 0411562984
cheers.
engine and gearbox gone!
turbo & dump - $160 (missing actuator on turbo)
front pipe - $50
new front rotors - $100 (gone orange from sitting outside, can be washed)
cross member - $50 (no gearbox mount)
