I will make this public.
This is about the final run of our PU high flowed unit running off .63 turbine housing.
This is running an internal wastegate with updated gate controller. Hold 18psi all the way to red line.
Full boost @ 4100RPM, made 294.8 RWKWs with wheel spin hitting rev limiter at 7200RPM.
  • Replies 48
That was all the way to rev limiter. Drop off was mainly from lose of traction. Sam did not back off early. You can double check with Sam if you want.
The Main point is that we've managed to controll and hold boost all the way to 18psi using an internal gate setup on a .63 turbine housing.
and
This turbo has made the most power out of all the R33/34 high flows there are with 98 RON Fuel.
what does the dyno chart only show 6300 not 7200...you are missing 900rpm
It wheel span off the rollers. Its not a hub dyno. the RPM is Derived from roller speed.
I'm trying to find a hub dyno locally for a some more accurate data. Please let me know any one got one of those dynos in the North suburbs
Also I don't think it can be any more responsive. It does feel abit lazy on the road. But for the power range its engineered for its not too bad.
pull it down man, pull it down.....seriously, it shouldn't wheelspin that early, consider changing tyre type.
190rwkw at 110km/h but at 4090 says it is reving too much throughout the range as well, otherwise very solid result.
Boosting at just sub 3000 is about right as well, in 4th I'd be doing it at around 2700 rpm with my 3076, so comparable.
and
take it to trent dude... he has a hub dyno :cool:
He's fully booked till 2 weeks later. I perfer to get it done sooner in my area. But I will go to see him sooner, haven't been to his shop for a while, and I've made lots of new things during this period.
Another Dr-Drift dyno run cut off early...rev it harder Sam :(
They are still nosing over after 5500 though stao...badly
+1 Another 650rpm graph :cool:
My car with what, 280rwkw was fine, no wheel spin on Sam's dyno, taken to 8000rpm...
Awesome results, but i'm really concerned about the manifold pressures. I want to know if you guys are monitoring the manifold pressures whilst holding the gate closed with the actuator stopper? im worried about excessive pressure doing damage long term (exhaust valves and rear turbine).
+1 Another 650rpm graph :(
Hoo means I've must made more torque and more power then you have. :cool: It have lost traction, you can confirm that with Sam.
This is sleeve bearing. Wheel sizes I probably want to keep in secret, its not a standard sized wheel. I might integrate the Ceramic BB cartridges into those down the track, hopefully it can pickup better response.
The turbine housing was close to get maxed. Sam said it was getting hot. I've changed the wastegate controller's design. Its got lot better adjustability now.
WOW pretty good result...
my internally gated 3071R kept dropped from 20 to around 16-17psi... would have cracked 300rwkw if it had kept consistent boost.
Well done...
is this turbo available for purchase? I have a friend looking to upgrade
LOL! this power is unbeliaable guys. Soon this turbo will be on mine! Guys Tao took me for a drive in this with the turbo on and it was just AMAZING! it was so torquay!!!!!!!!!!!!!!!!
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
