hey guys new to this site, just got myself a N/A 33 and the exhaust is already shitting me, its stock with a cannon, im looking for a increase of performance just wondering wat the best way to go and the best brands and prices if ya can helpme out
http://www.skylinesaustralia.com/forums/Po...sp-t194033.html
that should have most of the information you'll need, with brands it best not to go for the cheap fix as they are almost always crap, pay a good price for a good product
cheers bud, doesnt really specify in that post though, i was thinking a nice set of extractors with maybe a 2.25 or 2.5 system with high flow cat and i nice muffler, no cannon, sound anygood?
i think anything without a cannon sounds good, lol.
Get tuned length extractors, keep your stock cat or get a high flow cat if you can afford the $$$, 2 1/4 piping with whatever nice muffler (normal / high flow) tickles your fancy. That should set you up with a street legal nice system.
I measured my exhaust pipe when i had my cannon replaced and its only 2 1/4inch!! man was i annoyed now i know why my top end isn't that great, bottom end is great tho...
i would go with 2.5inch if i was you, but don't get a huge cannon on the end and if you can afford to, get a straight through resonator put on
thanks for the help. any ideas on the dollars i should be paying for that type of system, just dont wanna get ripped.
Mine cost $1100 for headers/extractors a resonator and a descent cannon, that was custom made with Coby branded parts.
If you pay anymore then that then your probably getting ripped off.
thanks bud, how are the coby parts?
ive got coby extractors on mine 2, the seem good so far, higher top end power and more response,
but the factory welds were 2 thick and the shop had to grind 2 of them down a bit to get washers on the bolts , but someone on here said coby has now addressed that issue? and someone also complained that they had the exhaust header flange warp, but it must not have been bolted up right cos its pretty thick, like 6mm
how much did they set ya back man and where abouts did u find em?
The best sounding exhuast system for a NA skyline would be
DKNE extractors - $500 with HPC coating is what i got mine for....
Custom front pipe and 100cell cat 2.5" - $500 again
Kakimoto Racing Kakimoto R (r33 NA 75mm muffler) - $1000
This is a really quiet setup its about 77dB but you can get it really loud if you ever wanted to buy just removing the intake silencer box in your engine bay. Pretty hefty price for a good exhaust system =\
I got a set of dkne extractors to be put in, just waiting on a varex muffler or cannon (still cant make up my mind to witch one to get, any care to help? PM me) ... quoted 500bucks to get it all installed with a high flow cat and 2.5" mandrel bent piping... Ive been told its a fair price and a good setup...
Thats exactly what i have, its a great setup imo. The varex + highflowcat eliminated 90% of the horrible raspy noise i had with just some random cannon on 2.5inch pipe with dkne extractors. Also have a resonator id recommend one :)
  • 1 month later...
 Share
    • It depends on what the guy who bought its Ratio is. Mine is a 4.36 Jus Jap told me anything above a 3:9 has equal length shafts which the Nismo center's shafts were not.
    • If those shafts in the last 2 photos are the ones that came with the diff, you have no hope of fitting the other ones because they are completely different
    • I have recently fitted a Nismo GT Pro Center second Hand buy still in the box i got stubs with it but they are 5 bolt and I need 6 (3x2) I was told by Just Jap that for a 4:36 ratio the stub axles are equal length sku 38220-0V161. They didn't have any in stock but I picked up the ones pictured. The one with 5 bolt are the ones that came with the LSD. The right side went in no issues but the right....I have happened the fk out of it put it in a press and it still sticks out about 5mm too far. It was sticking out about 25mm but after bashing it like Chris Brown did to Rhianna I managed to get it a bit further in but seems stuck again now. Any ideas? Should I just leave it 5mm out and send it?
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
