R33 HKS SUPER DRAGER EXHAUST 2.5" With custom Dump 200
R33 stock wheels silver no tires 100
R32 stock wheels black 150
R32 stock exhaust (i mean stock things fkn tinny) 100
Apexi SAF-C Air and fuel 400
Greddy Turbo Timer 100
Located in Melbourne
Edited by Q2CME
https://www.sau.com.au/forums/topic/321162-skyline-parts/
