Hey guys,
I'm tossing up between these two tyres because Tempe have quoted me the same price for both tyres in 18 inch.
Any suggestions which way I should go?
Regards,
i could be wrong but i think the 452's are meant to be the more expensive tyre model and is available in larger sizes. both have similar reviews from what i can tell.
I've 912's on both the R33 and FTO. Nice long wearing tyre. Excellent wet handling.
My tyre guy said the 452's would be better if were going to trackdays.
I think they're a softer tyre so less life. Correct me if wrong.
Thanks for that mate! Yeh every one of the tyre guys have been telling me to get the 452's, but they also seem to be the only ones in stock. Both Tempe and 7 Day Wheels and Tyres seem to be out of it when I call up and ask if they have any.
How are the 912's in terms of ride? quiet? bumpy?
I got quoted $180 for the rears & fronts. Tempe said $180 each and 7 Day Wheels and Tyres said they would match it.
When my car was complied, I paid $250 each for the Fronts and $300 each for the rears, so they are great prices. The 452's are soft though, only got 20,000km out of the rears.
Has anyone seen prices like that in Brisbane?
Hi All,
How do the Falkens compare to Bridgestone RE001 tyres?
I would say they are both good grippy tyres in the dry. RE001's have a bit of a problem in the wet so reckon the fk452's would be better.
I am currently running RE050A's on my V and have read articles that test them as pretty much equal to the 452's but nearly double the price.
I also have a second set of wheels with an early Jap domestic market model of the RE001's and while great in the dry they are absolutely terrible in the wet. Make the stability control come on nearly every corner.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
