hey everyone
i want to do modifications to my 1998 r34 gtt but i still couldnt decide which parts to get for my car, so i need your suggestions and experince if you dont mind.. i want my car to look as stock as possible and i dont want it to be the best GTT in the world but i do want it to make good power like around 230-250 rwkw, and since i’m not a mechanic i’m not sure how to choose the right parts....
ok i will start with the mods i have in the car
full exhaust system 3.5”
i have apexi power fc+ boost control kit
pod filter but i’m thinking about putting back the panel filter ( i need suggestions on that)
i want to get
-front mount intercooler ( i need one that would bolt on straight and uses the original smic pipes, but after researching i realized there is no such a thing as bolt on without modifying the front bar and cutting) ,, the one i have been looking at is http://justjap.com/store/product.php?produ...=339&page=1 (if you know one better than this one and doesnt need any modifying for a GTT please tell me and all suggestions are welcome) would i be able the get the intercooler engineered in NSW?
-high flow the stock turbo ( as i am looking for good response and stock look but cant decide should i get hypergear to do it for me or GCG?)
-injectors, i was thinking about hi flowing the stock injectors instead of buying aftermarket ones to keep the car stock and will be cheaper, but is it going to be reliable and live long??
-fuel pump ( i’m not sure if i need one for the power i’m after?? would the stock pump be good enough?)
i’m not even sure if the mods i want to do are good enough for the power i’m after so if someone thinks that i wont achieve 230-250 rwkw could he tell me what else do i need?and also could he tell me what kind of power will i be able to make with the mods i mentioned?
all help and suggestions are welcome and thank you guys in advanced
Baros B.
if you go the bigger turbo you will more than likely need to change the afm to something like a z32 afm as you may be getting close to maxing out the stock one. with a pfc you can tune just above where it maxes out, but you would be best getting the z32 afm.
good: retain stock fuel system, get highflow, FMIC and clutch shoot for 230rwkw
better: bosch 044, 450cc or bigger injectors, GCG or hypergear highflow, clutch, Z32 afm, FMIC and 250-270rwkw
best: bosch 044, 550cc or bigger injectors, garret 3071, button clutch, Z32 afm, FMIC, 280-290rwkw
Hamish,
FYI S15 injectors won't fit on 34 - Different voltage something along these lines.
R34 RB25 doesn't have wide range of injectors to choose from compared to R33 RB25 going by what I've researched.
thanks for the replies guys really helpful,,
so what about highflowing the injectors, would it be the best way to go?? i'm not looking to get my car to make more than 300kw even in the future,,, also does anyone know about wether it is possible to get an engineer certificate for a FMIC in NSW??
High flow injectors, when I talked to Trent @ Chequered Tuning (great guy), he said it's a hit or miss.
Better to buy Nismo or Blitz injectors.
As for intercooler, just get turn-flow unit (piping that plumbs to standard piping) is the way to go and don't bother getting it engineered, Mr Plod and their friends may ignore them (that is the case in Victoria - I don't know NSW though).
Hope it helps.
Cheers
Grant
I recently got a similar response from Trent re: Highflow injectors. Creatd do them for $85 an injector. (Recommended by Trent) Again, the vibe I got was they can be hit or miss. I don't know if the ones from Creatd are hit or miss, mind you. :P
Failing that, are there any other injectors that look stock to the ones in a RB25DET Neo?
Nope, but you can paint them to make them look stock?
Or man up and run them and if Mr Plod pull you over, try get his attention away from the injectors by asking retarded questions.
*DISCLAIMER* I take no responiblity should these above methods if they work or not. (never tried these as I've never been pulled over before)
The only visual difference between aftermarket injectors and stock injectors is the end of them usually being a colour. However once they are installed you can barely notice it. Anyway if you are that worried about some one noticing them, just paint the ends of them black.
i guess everyone agrees that highflowing the injectors is risky and i'm better off with an aftermarket injectors, from my research i found out that probably the nismo injectors are the best choice because they dont require any modification to the fuel rails or anything else and ( can someone correct me if i'm wrong please),,,
i think for now i will keep the stock fuel system to achieve the 230kw i'm after, then maybe in the future i'll upgrade the fuel system when i feel that i need more power
thanks everyone for your help really appreciate it
dont get the cooling pro cooler. they r shit seriously.
if u really want the return flow cooler get a blitz one or speak to thuy from j imports he has 2 arc return flow coolers in stock.
other than that
fuel pump
gt30 based turbo (something u can still hide under the heat shield)
injectors
upgrade ur coilpacks
z32
its funny how u say u wanna keep it stock looking but u have a 3.5 inch exhaust on it.
other than that
fuel pump
injectors
z32
-why are you saying that the cooling pro cooler is shit? i mean are they still shit for the kind of power i want to make which is 230rwkw?? (i’m not looking to make so much more power than that anytime in the next 2.5 years)
-for the turbo, i wanted to get highflowed because i dont want to spend so much money on a new turbo + there is a chance it could get defected + the same reason as the above i dont want to make too much power )
-when i was researching for fuel pumps i didnt know whats the difference between internal and external fuel pumps. what kind do i need to get for a GTT?
btw i should’ve clarified what i mean by stock looking earlier, i meant stock looking in the engine bay as much as possible.
again thank you all for your help, i really really appreciate every reply
Also invest in fuel pump - you don't really know when standard ones will fail, get Nismo which is drop in - no fiddling needed.
When you get a fuel pump is a FPR needed? I'm a little unsure when your actually meant to get a FPR when you get bigger injectors?
for the fuel pump, just go an internal unit such as a bosche 040 or a nismo.
for the intercooler, you really want to get the best one that you can afford. some of the cheap ones are ok, but others of the same brand can be crap. there just isn't the quality control of the better stuff.
you don't really need a FPR. just use the stock one
    • I figured out what’s wrong. It’s something to do with the high beam wire short circuiting. When I measure the continuity with a multimeter on the headlight socket connector it gives me a continuous beeping noise when I put it on the ground socket and also on the high beam socket.  On the passenger side of the car (working side), it’s only beeping when the probe is on the ground socket. Which makes sense.  So that means it has something to do with the high beam power supply for the drivers side. How do I trace that? Is it the turn signal lever malfunctioning? The one that also controls the high beam and low beams.
    • Hey lads just finished tidying up a gtr a bought. Originally from Sydney now living in New Zealand
    • Hi Guys, Looking for this piece if anyone can help out.   https://tfaspeed.com/products/nissan-skyline-r33-gtr-rear-trunk-finsher-panel
    • How did you go with your problem? End up fixing it. Have a y34 aswell vq30det
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
