From memory in 18x9.5 they come in +20 or +12. Either one of these will be well outside the standard front R32gtst guards, if your going wide body it won't be an issue though.
Ryan
Or if you're running a decent alignment with camber on the front for grip.
Sorry, if its a GTSt with std guards, even if the insides are rolled then its my experience that sized rim will not have a hope in hell of fitting on an R32 GTSt
I'm glad you're not fitting wheels to cars all around Australia then.
I run 9.5 +12s on the front of my R34 with no issues whatsoever, and 32 is very similar width, so the +20 should be fine. Just dial camber into it.
Looks retarded and not even close to fitting lol.
Which is why no-one on here has decent fitment.
That needs camber (like any performance alignment) and a little stretch and they'll tuck. If the guards were pulled a little it would fit with EASE.
lol I know :D, but you know how much the kids like their "fitment" these days........
So you're suggesting you don't understand it? Ok :P
So you're suggesting you don't understand it? Ok :D
1. Not at all champ, I understand it completely, but my 32 is a race car, running under very restrictive category rules, thus the camber I have, is the the most I can have.
2. Regardless, I favour good handling and rough road behaviour, than perceived "good fitment". :P
3. We swapped the LMGT4's off my 34 GTR over a carton of piss on a friday afternoon for shits n giggles.
2. Regardless, I favour good handling and rough road behaviour, than perceived "good fitment". :D
People also need to understand that fitment doesn't have to sacrifice handling etc.
But clearly under your regulations you do what you can. Clearly I'm talking about an open environment that allows for whatever you like.
Still doesn't mean it is a good idea. Why not just get the proper offset or slightly smaller rim that doesn't need to run race car amounts of camber to fit? Anymore than a degree or two on a road car is going to chew the crap out of the tyres.
Same goes for stretching tyres to the max, why not just get a slightly smaller rim and fit the correct sized tyre on, better performance and better tyre wear not to mention it is legal and doesn't look silly.
Because you're looking at it the wrong way.
I go a wider wheel, so the same size tyre can be used, but has the necessary stretch.
And with alignment, I set my car up with -3.5 camber because it is ALWAYS getting flogged in the hills so I set it up to be optimal. I don't set it up for driving to work and sacrifice it's performance under load.
But I also simply accept that my tyres will wear quicker (i'd change rear tyres 12 times a year anyway due to sliding the car).
^^^ Exactly, I think some folk missed the tongue in cheek "fitment" reference.
R34 GTR wheels go on my gts very nicely imo, what offset are they? Plus 22 aren't they?
They're 18x9 +30 :P
My R34 has 9.5 +12 all round without any guard pull at all. Just lips rolled :ermm:
Edited by BTM
^^^ It looks like your front guard has hit the rubber a fair bit there. Or is that a light reflection.
I highly doubt 3.5degree negative camber is ideal for road driving in a street car, even with proper semi-slicks.
And ECR32, 33 and 34 get wider guards with each model. Flush fitment looks good, significantly outside the guards just looks like a virgin P-plater rust bucket non-turbo 180sx living in 2006 when drift was kool.
Edited by simpletool
The damage on the guard was from when they weren't rolled and were rubbing hard. Fixed it all up and they don't rub at all now, so no issue of them bending. Was just my laziness that caused it initially.
And my mate runs 9 -5s under the front of his R32 with standard guards :)
As for being highly doubtful, I run more camber with street suspension than race sus because the car has a tendancy to roll more. I build my cars to be driven hard, not to be pussy footed around like most Skyline's you see these days :)
Edited by BTM
i run 9.5 +15's on my r34 and my guards are stretched alot and on the front they still stick out 10mm and the rear is flush. there is no chance in f**k they will fit on a gtst, gtr maybe deff not gtst
Thank you for showing you have no idea.
Already done it time and time again on them.
My 9.5 +12s on the front of my R34 sit maybe 2mm out of the guards, and no guard pulling at all.
It can be done, so don't say it can't.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
