hey guy's
got my r32 gts-t rb20det for four months now
but i have a problem at least i think
my stock oil pressure gauge is busted know problem
so i have a aftermarket oil pressure gauge
when its cold he is running around 5kg max
when the oil temp is at 60
on idle he is running at 1,5kg
when he is fully warmth up at 75 the oil pressure gauge says 0.5kg?
but when i am running at 3k rpm pressure is 3kg when im boosting around 4.5kg
engine running smooth no knock or what ever should get the oil change't with mutol 10/50
should i be scared?
Greets lennert
https://www.sau.com.au/forums/topic/321206-r32-oil-pressure-problem/
Seems to be not much wrong at all with those numbers.
As the oil heats up, it gets thinner and doesn't need as much pressure to pump it around the engine. As the engine revs, it pumps more oil in a given time, and produces more pressure (resistance to flow).
And you shouldn't use anything much heavier than 10/40 oil.
i find it a bit odd lol
because the red light from the aftermarket gauge goes on when im not revving
every time when i am standing still for a cross-section or stopsign i always play with the engine to keep oil pressure up
