RB20DET
After cleaning and re-installing the AAC Valve, the idle now sits at 1400rpm, higher when cold. Before cleaning the valve, the idle was 800-900rpm.
I have spent days reading through posts and trying to find a solution.
So far I have tried...
1. Adjusting idle screw (turned all the way in)
2. Reset ECU
3. Removed and cleaned IAC Valve
4. Re-gapped spark plugs to 0.8mm
5. Insulated coil packs with silicone
6. Checked all lines and connectors
After cleaning the IAC Valve last night, this morning the car was idling at 2000rpm all the way to work. It finally dropped after driving for 20 mins to 1600rpm. I noticed the spring inside was not fully closing the valve, obviously allowing some air to enter on idle. I presume this may contribute to the problem.
The only other problems I can think of is;
1. Gasket on AAC valve is faulty
2. Vac leak in or around plenum/manifold
3. Faulty TPS
I thought I might try adjusting the CAS but I wanted to post here first to see if anybody might be able to pinpoint the problem.
Any help would be appreciated, cheers.
https://www.sau.com.au/forums/topic/321234-high-idle/
You say it was idling at reasonable RPM prior to you cleaning it, and after the clean it's too high.
If the only item you've touched is the AAC valve, why go looking at other parts?
Usual culprit for high idle is the air reg but you haven't disconnected its plug or removed its hoses have you?
https://www.sau.com.au/forums/topic/321234-high-idle/#findComment-5241625
I thought the problem may have existed prior to the AAC Valve becoming dirty and that cleaning it improved air flow allowing a leak to cause high idle, thats why I was checking other parts. The AAC Valve was in good condition and the spring was tight, the only other thing I can think of is that the gasket may need replacing, could this cause high idle?
I havent removed any other plugs or hoses without replacing them, however i dont know what the air reg looks like or where is it located.
https://www.sau.com.au/forums/topic/321234-high-idle/#findComment-5241692
it could be the gasket .. did you damage it during the clean ? if so replace it. Also check that the throttle cable sits correctly .. if it doesn't revs will be up and its easy to miss
Its probably a combination of both to be honest. I also beleive the regulator assembly is stuffed as the spring dosent hold the metallic plate over the gap fully, allowing air to enter on idle.
I have ordered a new valve from Nissan and will check the throttle cable and valve gaskets.
https://www.sau.com.au/forums/topic/321234-high-idle/#findComment-5242175
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
