hey guys got heaps of stuff to clear
need to get rid of everything send me your offers
can ship most things aus wide at buyers expense
all items located in castle hill
contact: tilla txt 0402362885
genuine greddy limited edition type-RZ bov 2months old -$220
sr20 top mount manifold made by liverpool exhausts no leakes - $400
stock r33 bov 120 xxx ks - $50
r33 s1 bonnet suit respray - $80
r33 s1 right hand side fender blue in color excellent condition - $220
r33 s1 bonnet perfect condition blue in color with hinges - $350
r33 s1 bonnet latch with t bar
$30
r33 s1 reo uncut $140
stock r33 exhaust + cat (good for clearing defects) $80
jvc avx800 dvd head unit bought 2 years ago for 1700 been siting in project car ever since watched
2 dvds max! comes with the ipod adapter bought that for 200
all together selling it for -- $750
http://www.ryda.com.au/JVC-KW-AVX800-In-Dash-DVD-Monitor-p/kwavx800.htm
pioneer gm-7300 800w mono block rrp $330 used for 8 months in mums car barley used
--- $200
http://www.pioneer.com.au/Products/Archive/Car%20Entertainment/Amplifiers.aspx
heaps more parts to come!!
Edited by schnorky
https://www.sau.com.au/forums/topic/321247-garage-clean-out-open-to-offers/
UPDATE!!
genuine greddy limited edition type-RZ bov 2months old -$200
sr20 top mount manifold made by liverpool exhausts no leakes - $200
stock r33 bov 120 xxx ks - $40
r33 s1 bonnet suit respray - $50
r33 s1 right hand side fender blue in color excellent condition - $200
r33 s1 bonnet perfect condition blue in color with hinges - $300
$15
R33 s1 reo uncut $100
stock r33 exhaust + cat (good for clearing defects) $60 AND a pack of winnie gold :rofl:
2 dvds max! comes with the ipod adapter bought that for 200 SOLD!!!
--- $180
  • 1 month later...
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
