Hey guys,
recently I pulled my motor out of my r31 and decided to put it into a r34. I have bought a r34 now but I would like to know the issues I may face in doing the conversion. Surely someone here has already dropped a 30 into a 34 so would be good to get some knowledge of guys who have been there done that already.
Are there any clearance or looming issues? any majors?
all information will be helpful.
thanks guys
https://www.sau.com.au/forums/topic/321252-r34-rb30/
Hey guys,
thanks guys
30e(t) or 30de(t)?
https://www.sau.com.au/forums/topic/321252-r34-rb30/#findComment-5243263
Hey guys, the clutch issue you say? Well i have all running gear from my r31 which was initially r33 rb25det. It has a rb25de r32 head. And to answer the question it is a rb30DEt
p.s. that link pretty much advertised the car and specs, didn't have too much on the actual build or issues it had. I have basically a fully built motor ready to go in with all running gear just need to clarify what issues i might come across when doing the conversion.
I have heard there's issues with the bonnet closing with the standard "J pipe" as it fouls with the bonnet, to get around this you either have to cut the bonnet support or go front facing plenum. I'm not too keen to do either lol has anyone considered getting custom mounts to lower the engine level?
Edited by Redliner007
https://www.sau.com.au/forums/topic/321252-r34-rb30/#findComment-5249730
If it's RWD then you can slot the engine mounts to drop it down some.
Also the fouling I had (in my 32) was not the J-pipe, but the most forward corner of the intake plenum, and the lip of the timing belt cover.
https://www.sau.com.au/forums/topic/321252-r34-rb30/#findComment-5250352
Oh yeah so i can get away with lowering the mounts? thats a bit of a relief might even look at getting some aftermarket mounts/bushes while im at it since i will be saving the money from not going front facing.
Do you guys know if there is any major wiring issues?
Im also using a Link G4 ecu which was previously on a r32 loom, I would like to keep all the factory r34 gauges in working order to give it the "factory" appeal.
https://www.sau.com.au/forums/topic/321252-r34-rb30/#findComment-5250563
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
