hi everyone, im wrecking an R33 GTST Skyline. Got both s1 and s2 parts avaliable as it had a s1 front end on it. i have heaps of gear still on the car (fuel tank, diff, cradles, upper and lower arms, power steering pump, swaybars etc and panels) (sorry no photos yet) JUST ASK!!!
#1 R33 GTST Series 1 rear spoiler $50 ono
#2 x2 apexi BOV $60 ono each
#3 series1 headlights $200ono (pair)
#4 Windscreen washer bottle $20
#5 Radiator Fan $70ono
#6 unknown brand cannon, $50ono
#7 set of 17"x7" rims good tyres on 2, other 2 need replacing,
minor gutter rash but overallpretty good, (will not fit over large brake calipers) $600
#8 drivers door to suit 33 2dr, NO MIRROR, $80 post-35195-12720962536663_thumb.jpg
#9 Tail lights and centre garnish $200ono
#10 indicator/wiper lever assembly $40ono
#11 Brake booster $80ono (non abs)
#12 heater/aircon assembly $45ono HEATER PART - SOLD
#13 engine bay wiring loom $150
#14 Digital climate control unit $50
#15 Dash wiring loom $50
#16 Accelerator pedal and cable $30ono
#17 boot and petrol cap cable $15
#18 seatbelts $50 set
#19 petrol cap cover $10
#20 steering column barrel and key $70
#21 Front Hubs (pair $100 ono)
#22 Boot Lid and s2 Spoiler $150 ono incl gas struts and hinges
and lots of interior parts available, just ask.
all reasonable offers considered, as i need to move this gear.
cheers Ty
located in SA
https://www.sau.com.au/forums/topic/321265-wrecking-r33-gtst/
  • 3 weeks later...
  • 1 month later...
  • 1 year later...
Hi
Just looking for some interior parts for r33 gtst series 2 looking for the dash that surrounds the climate control and head deck. and dash surround around the cluster and steering wheel
cheers
trent
  • 2 years later...
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
