1999 Model JDM Nissan Silvia S15 Spec R For Sale
Pearl White
6 Speed Manual
Nov 2010 Rego
Car is in absolutely immaculate condition inside and out
It has a new Exedy clutch and flywheel was installed at 100,000kms
and the car has been religiously serviced every 5,000kms using quality products including a major service.
This included all fluids and filters replaced, gearbox and differential oil
replaced, new endless front and rear brake pads, new platinum spark plugs, timing chain inspected and a
front and rear wheel alignment.
This car is reasonably standard, but does have certain options from the factory as well as a few
aftermarket modifications.
- Engine:
Front mount intercooler and plumbing
HKS pod filter
HKS duel stage electronic valve controller (run at 12psi)
3inch turbo back exhaust with Tomei dump pipe
Blitz turbo timer
Exedy heavy duty clutch with Exedy lightweight flywheel
- Suspension:
Cusco adjustable coilovers front and rear
Cusco front strut brace
HKS adjustable castor rods
- Exterior:
17inch AVS Series-7 wheels
6000k HID headlights
Aero side skirts and rear pods
GT wing
Tinted windows
- Interior:
Aero orange suede interior with "Silvia" embroidery, very unique and rare option.
Genuine Silvia floor mats front and rear
Will be sad to see this car go after the effort put into finding, buying, modifying and maintaining it.
One of the tidiest JDM examples on the market
$25,500ono
0416 044 001
may swap
MASSIVE PRICE DROP
***Will not disappoint***
Edited by japgtr
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
    • Wow. Pissy much? You on a mission to find old posts to argue with, or is this legitimately just because you're 5 years into a 1 day job?
