zebra im not looking at a new ecu to make more power, 340klw at the wheels is plenty for what im doing with the car im just after better drivabilty i feel AFMs are just not consistant at giving accurate readings for the ECU which results in the car feeling sluggish at times,and yes they are new items.
choyda did yo have a powerFC before u got the vipec?
keep us updated on how your car turns out matt
cheers for the feed back guys!
Fair enough, Although many people say they loose drivability going MAP based with GTRs, they are bit tempremental in regards to where the MAP sensor is plummed into.
Hi,
I had the stock ECU and changed to Vipec to suit my mods. I did have a Power FC (no d-jetro) on my GTT. Certainly with the vi-pec the car drives like its standard (smoothness wise), seems to cope with different temps, cold starts, humid days much nicer than my Power FC did.
The tune also gives me surprisingly good fuel economy for a GTR anyway. I didn't have great economy in by GTT... could have been the tune though.
Damien
Not using the TPS as a correction with a MAP sesnor.
Guilt-toy is the v88 a plugin? if not do i need the v88 or will the v44 be fine?
V44 will be fine for a road car...same as we run in our street/circuit gtr with over 450awkw.
The only advantage of running a V88 is its direct fire ignition and the fact you have heaps of inputs and outputs for control/sensors etc.
Interesting, I need to go for a drive in a Vipec car that has had 1-3 hours of tuning. Be it Motec, Autronic, Microtech or Wolf (Never been in a car with a ViPec) the MAP sensed and tuned cars traditionally seemed to always require more dyno and road time to get the tune to the point where you got the drivability of the AFM Pfc and the fuel economy.
I do believe about 75% of it is in the tune and 25% of it the ECU. So if the ViPec and some of the softeware allows it to be quickly tuned and accurately tuned then that is a big bonus.
I have a Vipec V44 plug-in on my Stagea 260RS (R33 GTR engine). I also had the problem with the aircon clutch relay, but it's easy to fix. I believe the next runs of ECUs will have a fix for this anyway (if it's not out already). Either way, it's no biggy. Yeah, you don't have to wire in a wideband O2 sensor, but there are heaps of features you can access when you do. I just picked an Innovate one for $200, so will be wiring that in soon to trim my tune a bit more. I went from stock ECU to Vipec and it really does drive as smooth as stock. Mine has been tuned as mentioned above. 2 maps, 1 with TPS vs RPM and the other MAP vs RPM.
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
    • True! I think I'm closer to 06 with the cameras in phones being out there more. And the nearly impossible to use internet web browsers. Or paying for ring tones... Man I hated when we couldn't just compose a ringtone on a Nokia anymore! These days I just hate it if my phone rings, beeps, boops, or vibrates!
