Im willing to give ya all 4 for the price of one.... they have sat for a while so I'd get them checked first if I were you. They didnt leak on my car but that was some 3 years ago.
$50 they are yours...only after you have confirmed they dont leak, yep just throw us the cash if they are ok. Who knows you might get lucky and a couple are good.
LOL Like I'm EVER going to have a ca again...thats if they are 440s...I'll have to check first. Ill do that now so I dont forget. :D
LOL Like I'm EVER going to have a ca again...thats if they are 440s...I'll have to check first. Ill do that now so I dont forget. :P
awesome, thanks very much for helping me out! appreciate it :)
I'll only need to use them if my current one cant be fixed with new seals.
Shoot us a PM with any info
btw; what was the result of your car after the driver dynamics drift day? hopefully nothing expensive broke?
cheers
Hey Rekin, yours looks like it's the bottom seal. Mine looks loads worse than that. I really need to find a place with the seals for all injectors that don't want to charge half my left arm for them
the place where I got the injectors cleaned supplied seals too, but seeing as my bottom seal may be leaking i dont know if thats a good solution to your problem? haha
I could have just farked up the installation, will see once its pulled out if the seal is ripped etc
LOL nar was just the handbrake cable wrapped around the tailshaft. My car didnt like ripping up the handbrake as much I didnt haha. It rejected it.
Bad news on the injector front tho...they are actually red top ones. rx7s 550s maybe. I must have upgraded my gtr ones to these, so these will be useless for you. Im so sorry huni. Ill have a look through the rest of my parts on Sunday...never know whats in there.
Wished I could be more help...unless you can find 2 more of the red ones... :)
Wished I could be more help...unless you can find 2 more of the red ones... :P
good to hear it wasnt anything major
haha bummer no problem. Thanks for the searchin :)
Anyone else got a spare injector floating around?
cheers
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
